Multivariable minimization?
Multivariable minimization? - Messages
#1 Posted: 2012/2/26 08:32:30
I might be a bit annoying regarding this problem and, therefore, I apologize .
Here is a problem I struggled with for some time - without success.
The problem is quite frequent and requires the minimization of multivariable function:
There is the accompanied file - NLMinimization.sm
I can not find the solution when the function S( b ) has to be minimized regarding to vector "b". You could see in the file that I did the linear fitting and it could serve as an initial guess for the nonliner fitting - this is a coomon thing. I tried the usual thing - finding the roots of the first derivatives of S( b ) on each element of vector "b" using roots or standard Newton-Raphson method. Whatever I tried regarding this, I failed. If someone is willing to try to solve this and will have success - I would be very grateful.
