3D-Scatter Plot
3D-Scatter Plot - How can I plot it - Messages
#1 Posted: 2023/5/5 06:29:56
Valery Ochkov
Valery Ochkov
64 likes in 670 posts.
How can I plot 3-D diagram? So for example.
See please the SMath attach!
GTU-Ro-T.sm (383.51 KiB) downloaded 791 time(s).
#2 Posted: 2023/5/5 08:32:19
1. Arrays dimension do not match.
2. Once doctored, maybe Maxima.
#3 Posted: 2023/5/5 09:25:47
... a bit doctored.
GTU-Ro-T.sm (393.15 KiB) downloaded 754 time(s).
#4 Posted: 2023/5/5 12:11:50
1,308 likes in 2,221 posts.
If the Maxima Plugin is an option for you, then just create a n x 3 data matrix and plot it using Draw3D. You find more plot examples in my Handbuch (section 8.1).
GTU-Ro-T_Kr.sm (395.9 KiB) downloaded 778 time(s).
#5 Posted: 2023/5/5 15:06:56
Dustin Reynolds
Dustin Reynolds
0 likes in 1 posts.
thank you for your hard work... i am learning Smath because im fed up with ptc bullcrap.
ohh how i wish i had mCad 15 on this computer, but dont have my original disk...plus this is an opportunity to become a better programmer, learning
from all of the work on plug-ins etc...
hopefully we can some day graph a 3d scatter plot which will do what i did years ago with Mcad.
enjoy the clip..i may have smoked too much at that the time i made it.
In response to this Thread...I have a question.. I modified points-joined=false and it works, but how can I get Points instead of little crosses?
Funny Orbits 3.zip (3.61 MiB) downloaded 251 time(s).
#6 Posted: 2023/5/5 16:29:48
1,078 likes in 1,749 posts.
Also you can use a 3x2 matrix for rotate and project 3-D data into 2-D for plot it.
Click to enlarge
GTU-Ro-T.sm (397.19 KiB) downloaded 782 time(s).
#7 Posted: 2023/5/5 17:16:54
... differently by doing what's wanted.
3D Plot.sm (61.83 KiB) downloaded 739 time(s).
3D Axes System XYZ User Explorer.sm (52.17 KiB) downloaded 793 time(s).
3D Axes System Parametric Explorer.sm (21.02 KiB) downloaded 776 time(s).
3D Solid cut by Surface.sm (72.29 KiB) downloaded 766 time(s).
#8 Posted: 2023/5/5 21:04:08
...project 2D on 3D
Analemma [Project_Anim].sm (33.25 KiB) downloaded 650 time(s).
Analemma PROJECTION.sm (81.08 KiB) downloaded 782 time(s).
