Kilowatt hour (kWh) in SMath Studio
Kilowatt hour (kWh) in SMath Studio - Messages
#1 Posted: 2011/10/31 03:04:44
LCConservative
LCConservative
0 likes in 1 posts.
I would like to use SMath Studio for calculations involving kilowatt-hour units, the standard unit of energy that electrical power is billed in, and by which power production systems are described. Trying to derive the unit yields numerically correct results, but the values are odd because they are express in strange units.
Is there a way to use the unit kWh in SMath Studio and have the page calculate correctly?
#2 Posted: 2011/11/4 21:34:55
Edward Ulle
Edward Ulle
21 likes in 182 posts.
Not being an electrical engineer I can not attest to use of these units but, you can define your own units based on built-in units. For example I create units kWh by typing ' followed by kWh followed by : and then a mathematical equation combining built-in units. Remember to type single quote ' whenever you want to insert units. In the last line go to the end of the line where the J appears. A small blackened rectangle appears. Place the cursor at the end of the line and type ' and kWh.
[LIVE width=202 height=220]http://smath.info/live/?file=3202[/LIVE]
Ed
#3 Posted: 2022/8/21 13:35:37
thin
thin
0 likes in 2 posts.
I was having trouble with this too, and got here via google.
kW and W are built-in units within SMath.
h is a built-in unit, but is the Planck constant.
hr is the built-in unit for hours.
for the kilowatt-hour, which is normally written as 'kWh', you'll need to use kW*hr in SMath.
#4 Posted: 2022/8/21 15:30:03
kWh is universal ,,, in Uconeer it appears kW.h
under Energy+work category... missing in Smath
1*kW*hr=3600000J
#5 Posted: 2022/8/22 08:38:19
Hello thin,
You will see more units curiosities !
#6 Posted: 2022/8/22 09:09:28
598 likes in 1,380 posts.
You can create your own custom kWh unit.
Copy and paste this to smath 'kWh:1*'kW*'hr.
I wouldn't, but it can be done.
