1 Pages (2 items)
xcb xlib failure of Mono version - xcb xlib too much data request failure of Mono version - Messages
error.txt (21.44 KiB) downloaded 1353 time(s).
Dear Sir,
Thank you for your great engineering software SMath.
I tried to run the SMath (mono version, 0.99.7822) on my Ubuntu(Ubuntu 18.04.5 64bit).
I got the following error.
Please, help me.
Thank for your help!.
Best regards,
David error.txt (22kb) downloaded 0 time(s).
(base) kings@kings-MS-7C82:~/SMath$ ./SMathStudio_Desktop.exe
- [AppDir] AreaRegion 1.11.7822.147 (5 ms.)
- [AppDir] StandardToolboxButtons 1.1.7822.147 (5 ms.)
- [AppDir] MathRegion 1.11.7822.147 (5 ms.)
- [AppDir] ImageFileType 1.11.7822.147 (3 ms.)
- [AppDir] PlotRegion 1.11.7822.147 (5 ms.)
- [AppDir] HTMLFileType 1.14.7822.147 (5 ms.)
- [AppDir] SpecialFunctions 1.12.7822.147 (4 ms.)
- [AppDir] PictureRegion 1.10.7822.147 (3 ms.)
- [AppDir] SMathFileType 1.11.7822.147 (5 ms.)
- [AppDir] ViewerFileType 1.1.7822.147 (0 ms.)
- [AppDir] XMCDFileType 1.12.7822.147 (0 ms.)
- [AppDir] TextRegion 1.11.7822.147 (0 ms.)
- [UserDir] Custom Functions 1.1.7840.30466 (13 ms.)
[xcb] Too much data requested from _XRead
[xcb] This is most likely caused by a broken X extension library
[xcb] Aborting, sorry about that.
cli: ../../src/xcb_io.c:741: _XRead: assertion `!
실패.
Stacktrace:
at <0xffffffff>
at (wrapper managed-to-native) System.Windows.Forms.X11Keyboard.XCreateFontSet (intptr,string,intptr&,int&,intptr) <0x0008d>
at System.Windows.Forms.X11Keyboard.CreateOverTheSpotXic (intptr,intptr) <0x000cb>
at System.Windows.Forms.X11Keyboard.CreateXic (intptr,intptr) <0x000e7>
at System.Windows.Forms.X11Keyboard.CreateXicForWindow (intptr) <0x00037>
at System.Windows.Forms.X11Keyboard.FocusIn (intptr) <0x0009f>
at System.Windows.Forms.XplatUIX11.SetFocus (intptr) <0x000d3>
at System.Windows.Forms.XplatUI.SetFocus (intptr) <0x00024>
at System.Windows.Forms.ContainerControl.SendControlFocus (System.Windows.Forms.Control) <0x0009f>
at (wrapper remoting-invoke-with-check) System.Windows.Forms.ContainerControl.SendControlFocus (System.Windows.Forms.Control) <0x0006b>
at System.Windows.Forms.MdiClient.SendFocusToActiveChild () <0x00037>
at (wrapper remoting-invoke-with-check) System.Windows.Forms.MdiClient.SendFocusToActiveChild () <0x0005b>
at System.Windows.Forms.Form.Activate () <0x00063>
at SMath.UI.Desktop.MainForm. (object,System.EventArgs) <0x00017>
at System.Windows.Forms.Form.OnLoad (System.EventArgs) <0x0007c>
at System.Windows.Forms.Form.OnLoadInternal (System.EventArgs) <0x0007f>
at System.Windows.Forms.Form.OnCreateControl () <0x00057>
at System.Windows.Forms.Control.CreateControl () <0x0011f>
at System.Windows.Forms.Control.WmShowWindow (System.Windows.Forms.Message&Wink <0x0017b>
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message&Wink <0x002d7>
at System.Windows.Forms.ScrollableControl.WndProc (System.Windows.Forms.Message&Wink <0x00013>
at System.Windows.Forms.ContainerControl.WndProc (System.Windows.Forms.Message&Wink <0x0005b>
at System.Windows.Forms.Form.WndProc (System.Windows.Forms.Message&Wink <0x00263>
at System.Windows.Forms.Control/ControlWindowTarget.OnMessage (System.Windows.Forms.Message&Wink <0x00024>
at System.Windows.Forms.Control/ControlNativeWindow.WndProc (System.Windows.Forms.Message&Wink <0x0003a>
at System.Windows.Forms.NativeWindow.WndProc (intptr,System.Windows.Forms.Msg,intptr,intptr) <0x003a4>
at System.Windows.Forms.XplatUIX11.SendMessage (intptr,System.Windows.Forms.Msg,intptr,intptr) <0x004af>
at System.Windows.Forms.XplatUIX11.MapWindow (System.Windows.Forms.Hwnd,System.Windows.Forms.WindowType) <0x00217>
at System.Windows.Forms.XplatUIX11.CreateWindow (System.Windows.Forms.CreateParams) <0x00df3>
at System.Windows.Forms.XplatUI.CreateWindow (System.Windows.Forms.CreateParams) <0x00024>
at System.Windows.Forms.NativeWindow.CreateHandle (System.Windows.Forms.CreateParams) <0x0003f>
at System.Windows.Forms.Control.CreateHandle () <0x00069>
at System.Windows.Forms.Form.CreateHandle () <0x00027>
at System.Windows.Forms.Control.CreateControl () <0x00087>
at System.Windows.Forms.Control.SetVisibleCore (bool) <0x00083>
at System.Windows.Forms.Form.SetVisibleCore (bool) <0x00353>
at System.Windows.Forms.Control.set_Visible (bool) <0x00032>
at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control.set_Visible (bool) <0x0006b>
at System.Windows.Forms.Application.RunLoop (bool,System.Windows.Forms.ApplicationContext) <0x00373>
at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext) <0x0005b>
at System.Windows.Forms.Application.Run (System.Windows.Forms.Form) <0x00037>
at SMath.UI.Desktop.Program. (string[]) <0x002e3>
at (wrapper runtime-invoke).runtime_invoke_void_object (object,intptr,intptr,intptr) <0x000d1>
Native stacktrace:
/usr/bin/cli(+0xc8514) [0x564b0cd87514]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x12980) [0x7fe030a39980]
/lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7) [0x7fe03045cfb7]
/lib/x86_64-linux-gnu/libc.so.6(abort+0x141) [0x7fe03045e921]
/lib/x86_64-linux-gnu/libc.so.6(+0x3048a) [0x7fe03044e48a]
/lib/x86_64-linux-gnu/libc.so.6(+0x30502) [0x7fe03044e502]
/usr/lib/x86_64-linux-gnu/libX11.so.6(+0x3ecc9) [0x7fe02cbf8cc9]
/usr/lib/x86_64-linux-gnu/libX11.so.6(_XRead32+0x25) [0x7fe02cbf9825]
/usr/lib/x86_64-linux-gnu/libX11.so.6(XListFontsWithInfo+0x3a0) [0x7fe02cbdac70]
/usr/lib/x86_64-linux-gnu/libX11.so.6(+0x766c1) [0x7fe02cc306c1]
/usr/lib/x86_64-linux-gnu/libX11.so.6(XCreateOC+0xfc) [0x7fe02cbe743c]
/usr/lib/x86_64-linux-gnu/libX11.so.6(XCreateFontSet+0x5f) [0x7fe02cbdb72f]
[0x4198a46e]
Debug info from gdb:
[New LWP 13817]
[New LWP 13818]
[New LWP 13819]
[New LWP 13820]
[New LWP 13821]
[New LWP 13822]
[New LWP 13823]
[New LWP 13824]
[New LWP 13825]
[New LWP 13826]
[New LWP 13827]
[New LWP 13828]
[New LWP 13829]
[New LWP 13830]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
0x00007fe030a3932a in __waitpid (pid=13833, stat_loc=0x7ffca72355ac, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:30
30 ../sysdeps/unix/sysv/linux/waitpid.c: 그런 파일이나 디렉터리가 없습니다.
Id Target Id Frame
* 1 Thread 0x7fe0315fe780 (LWP 13815) "Main" 0x00007fe030a3932a in __waitpid (pid=13833, stat_loc=0x7ffca72355ac, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2 Thread 0x7fe02f7ff700 (LWP 13817) "SGen worker" 0x00007fe030a34ad3 in futex_wait_cancelable (private=, expected=0, futex_word=0x564b0d27aa08) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
3 Thread 0x7fe02d7d2700 (LWP 13818) "Finalizer" 0x00007fe030a377c6 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=0, futex_word=0x564b0d26b640) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
4 Thread 0x7fe01e385700 (LWP 13819) "Main" __lll_lock_wait () at ../sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:135
5 Thread 0x7fe01c047700 (LWP 13820) "Main" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe01c046cb0, expected=0, futex_word=0x564b0d27b6c8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
6 Thread 0x7fe0151ff700 (LWP 13821) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0151fecc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
7 Thread 0x7fe014ffe700 (LWP 13822) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe014ffdcc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
8 Thread 0x7fe014dfd700 (LWP 13823) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe014dfccc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
9 Thread 0x7fe014bfc700 (LWP 13824) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe014bfbcc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
10 Thread 0x7fe0149fb700 (LWP 13825) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0149facc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
11 Thread 0x7fe0147fa700 (LWP 13826) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0147f9cc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
12 Thread 0x7fe0145f9700 (LWP 13827) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0145f8cc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
13 Thread 0x7fe0143f8700 (LWP 13828) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0143f7cc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
14 Thread 0x7fdfeffff700 (LWP 13829) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fdfefffecc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
15 Thread 0x7fdfefdfe700 (LWP 13830) "Threadpool work" 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fdfefdfdcc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
Thread 15 (Thread 0x7fdfefdfe700 (LWP 13830)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fdfefdfdcc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fdfefdfdcc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fdfefdfdcc0) at pthread_cond_wait.c:667
#3 0x0000564b0ce87ed6 in ?? ()
#4 0x0000564b0ce81be1 in ?? ()
#5 0x0000564b0cf4114a in ?? ()
#6 0x00007fe030a2e6db in start_thread (arg=0x7fdfefdfe700) at pthread_create.c:463
#7 0x00007fe03053f71f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 14 (Thread 0x7fdfeffff700 (LWP 13829)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fdfefffecc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fdfefffecc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fdfefffecc0) at pthread_cond_wait.c:667
#6 0x00007fe030a2e6db in start_thread (arg=0x7fdfeffff700) at pthread_create.c:463
Thread 13 (Thread 0x7fe0143f8700 (LWP 13828)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0143f7cc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fe0143f7cc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fe0143f7cc0) at pthread_cond_wait.c:667
#6 0x00007fe030a2e6db in start_thread (arg=0x7fe0143f8700) at pthread_create.c:463
Thread 12 (Thread 0x7fe0145f9700 (LWP 13827)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0145f8cc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fe0145f8cc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fe0145f8cc0) at pthread_cond_wait.c:667
#6 0x00007fe030a2e6db in start_thread (arg=0x7fe0145f9700) at pthread_create.c:463
Thread 11 (Thread 0x7fe0147fa700 (LWP 13826)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0147f9cc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fe0147f9cc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fe0147f9cc0) at pthread_cond_wait.c:667
#6 0x00007fe030a2e6db in start_thread (arg=0x7fe0147fa700) at pthread_create.c:463
Thread 10 (Thread 0x7fe0149fb700 (LWP 13825)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0149facc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fe0149facc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fe0149facc0) at pthread_cond_wait.c:667
#6 0x00007fe030a2e6db in start_thread (arg=0x7fe0149fb700) at pthread_create.c:463
Thread 9 (Thread 0x7fe014bfc700 (LWP 13824)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe014bfbcc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fe014bfbcc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fe014bfbcc0) at pthread_cond_wait.c:667
#6 0x00007fe030a2e6db in start_thread (arg=0x7fe014bfc700) at pthread_create.c:463
Thread 8 (Thread 0x7fe014dfd700 (LWP 13823)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe014dfccc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fe014dfccc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fe014dfccc0) at pthread_cond_wait.c:667
#6 0x00007fe030a2e6db in start_thread (arg=0x7fe014dfd700) at pthread_create.c:463
Thread 7 (Thread 0x7fe014ffe700 (LWP 13822)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe014ffdcc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fe014ffdcc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fe014ffdcc0) at pthread_cond_wait.c:667
#6 0x00007fe030a2e6db in start_thread (arg=0x7fe014ffe700) at pthread_create.c:463
Thread 6 (Thread 0x7fe0151ff700 (LWP 13821)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe0151fecc0, expected=0, futex_word=0x564b0e072ec4) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fe0151fecc0, mutex=0x564b0e072ec8, cond=0x564b0e072e98) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0e072e98, mutex=0x564b0e072ec8, abstime=0x7fe0151fecc0) at pthread_cond_wait.c:667
#6 0x00007fe030a2e6db in start_thread (arg=0x7fe0151ff700) at pthread_create.c:463
Thread 5 (Thread 0x7fe01c047700 (LWP 13820)):
#0 0x00007fe030a35065 in futex_abstimed_wait_cancelable (private=, abstime=0x7fe01c046cb0, expected=0, futex_word=0x564b0d27b6c8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x7fe01c046cb0, mutex=0x564b0d27b6e0, cond=0x564b0d27b6a0) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0x564b0d27b6a0, mutex=0x564b0d27b6e0, abstime=0x7fe01c046cb0) at pthread_cond_wait.c:667
#3 0x0000564b0cf3fe7f in ?? ()
#4 0x0000564b0ce86e0e in ?? ()
#5 0x0000564b0ce81be1 in ?? ()
#6 0x0000564b0cf4114a in ?? ()
#7 0x00007fe030a2e6db in start_thread (arg=0x7fe01c047700) at pthread_create.c:463
#8 0x00007fe03053f71f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 4 (Thread 0x7fe01e385700 (LWP 13819)):
#0 __lll_lock_wait () at ../sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:135
#1 0x00007fe030a32fb3 in __pthread_mutex_cond_lock (mutex=mutex@entry=0x564b0da2f180) at ../nptl/pthread_mutex_lock.c:80
#2 0x00007fe030a3499f in __pthread_cond_wait_common (abstime=0x0, mutex=0x564b0da2f180, cond=0x564b0db275a0) at pthread_cond_wait.c:645
#3 __pthread_cond_wait (cond=0x564b0db275a0, mutex=0x564b0da2f180) at pthread_cond_wait.c:655
#4 0x00007fe02cbf8882 in _XReply () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#5 0x00007fe02cbdcdde in XGetGeometry () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#6 0x00007fe02c124aaa in GdipCreateFromXDrawable_linux () from /usr/lib/libgdiplus.so.0
#7 0x000000004196788c in ?? ()
#8 0x00000000ffffff0f in ?? ()
#9 0x0000000002c00018 in ?? ()
#10 0x00007fe01e3844c8 in ?? ()
#11 0x00007fe03152d130 in ?? ()
#12 0x0000000002c00018 in ?? ()
#13 0x00007fe018001be0 in ?? ()
#14 0x00007fe01c074220 in ?? ()
#15 0x00007fe01e384300 in ?? ()
#16 0x00007fe01e383fb0 in ?? ()
#17 0x00000000419677c8 in ?? ()
#18 0x0000000000000000 in ?? ()
Thread 3 (Thread 0x7fe02d7d2700 (LWP 13818)):
#0 0x00007fe030a377c6 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=0, futex_word=0x564b0d26b640) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 do_futex_wait (sem=sem@entry=0x564b0d26b640, abstime=0x0) at sem_waitcommon.c:111
#2 0x00007fe030a378b8 in __new_sem_wait_slow (sem=0x564b0d26b640, abstime=0x0) at sem_waitcommon.c:181
#3 0x0000564b0cea3dc9 in ?? ()
#6 0x00007fe030a2e6db in start_thread (arg=0x7fe02d7d2700) at pthread_create.c:463
Thread 2 (Thread 0x7fe02f7ff700 (LWP 13817)):
#0 0x00007fe030a34ad3 in futex_wait_cancelable (private=, expected=0, futex_word=0x564b0d27aa08) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1 __pthread_cond_wait_common (abstime=0x0, mutex=0x564b0d27aa20, cond=0x564b0d27a9e0) at pthread_cond_wait.c:502
#2 __pthread_cond_wait (cond=0x564b0d27a9e0, mutex=0x564b0d27aa20) at pthread_cond_wait.c:655
#3 0x0000564b0cf0f863 in ?? ()
#4 0x00007fe030a2e6db in start_thread (arg=0x7fe02f7ff700) at pthread_create.c:463
#5 0x00007fe03053f71f in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Thread 1 (Thread 0x7fe0315fe780 (LWP 13815)):
#0 0x00007fe030a3932a in __waitpid (pid=13833, stat_loc=0x7ffca72355ac, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:30
#1 0x0000564b0cd875f0 in ?? ()
#2
#3 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:51
#4 0x00007fe03045e921 in __GI_abort () at abort.c:79
#5 0x00007fe03044e48a in __assert_fail_base (fmt=0x7fe03158c228 "%s%s%s:%u: %s%sassertion `%s' 실패.\n%n", assertion=assertion@entry=0x7fe02cc69430 "!xcb_xlib_too_much_data_requested", file=file@entry=0x7fe02cc69053 "../../src/xcb_io.c", line=line@entry=741, function=function@entry=0x7fe02cc69460 "_XRead"Wink at assert.c:92
#6 0x00007fe03044e502 in __GI___assert_fail (assertion=0x7fe02cc69430 "!xcb_xlib_too_much_data_requested", file=0x7fe02cc69053 "../../src/xcb_io.c", line=741, function=0x7fe02cc69460 "_XRead"Wink at assert.c:101
#7 0x00007fe02cbf8cc9 in _XRead () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#8 0x00007fe02cbf9825 in _XRead32 () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#9 0x00007fe02cbdac70 in XListFontsWithInfo () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#10 0x00007fe02cc306c1 in ?? () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#11 0x00007fe02cbe743c in XCreateOC () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#12 0x00007fe02cbdb72f in XCreateFontSet () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#13 0x000000004198a46e in ?? ()
#14 0x0000000000000000 in ?? ()
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
중지됨 (core dumped)
Dear Sir,
Please, help me.
Best regards,
Stacktrace:
at
Native stacktrace:
[0x4198a46e]
[New LWP 13817]
[New LWP 13818]
[New LWP 13819]
[New LWP 13820]
[New LWP 13821]
[New LWP 13822]
[New LWP 13823]
[New LWP 13824]
[New LWP 13825]
[New LWP 13826]
[New LWP 13827]
[New LWP 13828]
[New LWP 13829]
[New LWP 13830]
Id Target Id Frame
#2
중지됨 (core dumped)
I have the same issue in Ubuntu 21.10. I can start SMathStudio using sudo.
1 Pages (2 items)
