RC: SMath Studio 0.97.5301 (07 July 2014) - Messages
This is a decimal separator issue. If you use the period as dec sep, then units with subscripts display correctly (SS-173)
WroteThis is a decimal separator issue. If you use the period as dec sep, then units with subscripts display correctly (SS-173)
thanks
I seem to have a problem with "Areas"
Try this:
1. Type Text (call this top text)
2. Insert Area below text
3. Type in area (call this "in area text")
4. close area (note that this does not include "top text")
5. Open area
6. Move top area line above the "Top Text" so that it is not inside the area
7. Close area
8. Notice that the "top text does not close into the area"
9. However, Save the file, close SMath and restart the program. Open the file and all is fine.
Anyone else has this issue?
Try this:
5. Open area
7. Close area
There are already known problems with area region (see this in Bugs SS-171 for instance). Moving area handlers is an especially risky operation. SMath can crash easily than.
