"include" plugin: default directory setting
"include" plugin: default directory setting - Messages
#1 Posted: 2016/4/4 01:19:58
Mike Kaganski
Mike Kaganski
184 likes in 434 posts.
When using include plugin, it's sometimes inconvenient to use full paths, esp. when working on different setups. E.g., at work, I would like to have a network share with library files, which are included in a number of working files. At home, I would like to copy the whole library someplace at my PC, and continue to work with my workfiles.
Currently, I only can do it introducing some string path variable and setting it at each place. The proposal is to add a setting for include plugin, so that it's possible to setup a "library" (default location) path, and in case of relative paths in include(), look there.
Btw, is there in SMath an interface to add to settings dialog, or to Tools menu?
С уважением, Михаил Каганский
#2 Posted: 2016/4/4 02:00:57
1,554 likes in 1,864 posts.
You can use relative paths but for the "\extensions\" directory only for now. You can download Linq.sm example from the gallery and use it with the command:
include("examples\Linq.sm" )=
I can change this behavior.
Mike Kaganski 2016/4/4 02:18:00
#3 Posted: 2016/4/4 02:19:45
Mike Kaganski
Mike Kaganski
Oh, yes, you see, it's not convenient with \extensions\ as it is now. It wouldn't be great for any fixed directory, either, that's why I ask for customizable (at program level) directory, if possible.
Thank you!
#4 Posted: 2016/4/4 03:11:11
1,443 likes in 2,935 posts.
Nope, but it is possible to support the request of such feature here: (SS-70)
