copy/paste from smath to forum not working
copy/paste from smath to forum not working - Messages
#1 Posted: 2009/9/13 04:07:59
mar
mar
0 likes in 13 posts.
In the windows version I do not seem able to copy a selection from the smath sheet and paste it into one of these "forum" pages.
#2 Posted: 2009/9/13 07:34:20
Hello mar,
You have to select the expression, or part of it, copy and paste it into MATH BB/ code (Use "Quote" this and other massages and compare it to what you see in the posts). Pay attention about Regional Settings. The function arguments separator must be ";" and not ","
[MATH]if(x≡0;y←1;y←2)[/MATH]
#3 Posted: 2009/9/13 12:11:31
mar
mar
Not sure I understand what you are saying. Can you provide a more detailed example of how to make the copy&paste. Why can't I just copy&paste between the two applications using the stnd clip board method?
#4 Posted: 2009/9/13 20:25:35
2,315 likes in 3,949 posts.
Well. Throw the clipboard you can share any separate math expression from the SMath Studio application (you cannot copy couple of expressions in one time) only using MATH forum tag (or several MATH tags for every expression). Please, take a look on the screenshots below:
Figure 1: Using MATH tag of the SMath Studio forum.
Figure 2: Copying of the separate expression to the forum via standard system clipboard.
Note: you should use char ';' as a function arguments delimiter and ',' - as a decimal places separator of the number. You should take care of this by yourself because in some countries ',' character is for functions arguments and '.' - decimal places separator. I hope to find a time to fix this soon, but for now it's so...
omorr, thank you
#5 Posted: 2009/9/14 06:36:49
You are welcome
What about this? You can gather all the explanations you've made by now and put it in one forum, named say, "Read this first" or something like that. You might save the time explaining the same things many times. Just redirect the users to that forum. If you add another or new explanation, put it in that forum and redirect the user there.
#6 Posted: 2009/9/14 08:47:37
What about this?
Will do of course.
