Inversing Matrix in MES algorithme
Inversing Matrix in MES algorithme - Problem with inversing Matrix - Messages
#1 Posted: 2018/8/27 14:20:21
Krystian
Krystian
0 likes in 2 posts.
I have an issue when I try to inverse matrix without defining new variable Smath does a calculation, but when I try to define new variable with value of inversed matrix smath stucks in calculation. I attached a file, hope You can help me
RAMA3.sm (52.97 KiB) downloaded 707 time(s).
#2 Posted: 2018/8/27 15:34:15
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Try the eval () function
#3 Posted: 2018/8/27 16:41:22
116 likes in 332 posts.
By opening your file, errors correspond to two incomplete formulas. If you delete the two missing terms (one for formula) and if you set the rating to "numeric" (in your file The two formulas are set to "symbolic"), everything will work correctly.
[albumimg]1510[/albumimg]
[albumimg]1511[/albumimg]
Sergio
#4 Posted: 2018/8/27 20:27:56
Few things are not defined. Doctored in red, red is numeric.
Observe ... diag(v)
RAMA3.sm (68.17 KiB) downloaded 715 time(s).
#5 Posted: 2018/8/28 03:03:20
Krystian
Krystian
0 likes in 2 posts.
Formulas was incomplete because of having problems with calculating equation. Your solutions helped me. Thank You everyone, thread's exhausted
