Hydraulic calculation of the pipeline
Hydraulic calculation of the pipeline - Messages
#1 Posted: 2021/11/6 13:46:38
Tolik
Tolik
0 likes in 7 posts.
Hello.
I just started to study the program on my own.
And I don’t know how to build dependency graphs V(Q), Re(Q), lambda(Q) and delta p1 (Q) (see the file).
Сan you help with advice?
Thanks in advance.
Raschjot gidrolinii.sm (17.32 KiB) downloaded 1077 time(s).
#2 Posted: 2021/11/6 15:38:53
Maybe Colebrook will help to complete your document.
Raschjot gidrolinii [incomplete].sm (18.45 KiB) downloaded 928 time(s).
Inst_Colebrook Pipe Data.sm (71.45 KiB) downloaded 1051 time(s).
Tolik 2021/11/6 16:41:00
#3 Posted: 2021/11/6 16:42:30
Tolik
Tolik
0 likes in 7 posts.
Thank you for the help
#4 Posted: 2021/11/6 16:49:50
598 likes in 1,380 posts.
Here is a tip to your projects.
SMath vector/matrix/array indexes start from 1, not 0.
That will cause problems on your worksheets.
If you are rewriting a page from mathcad or similar, keep this in mind.
Tolik 2021/11/7 06:23:00
#5 Posted: 2021/11/7 06:29:25
Tolik
Tolik
0 likes in 7 posts.
Thanks for the help.
I found another mistake.
Everything works now.
Now I'm trying to plot graphs...
Raschjot gidrolinii.sm (1.68 MiB) downloaded 1115 time(s).
#6 Posted: 2021/11/7 08:16:26
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Changed the code a little and built a variant of the graphs
Raschjot gidr.sm (40.2 KiB) downloaded 1096 time(s).
Tolik 2021/11/7 10:01:00
#7 Posted: 2021/11/7 10:38:05
Tolik
Tolik
0 likes in 7 posts.
Your solution is very beautiful
#8 Posted: 2021/11/7 10:39:02
I saved in my personal file.
Check Δp ... it looks bizarre.
Inst_Colebrook PipeLine [unk].sm (19.78 KiB) downloaded 897 time(s).
Tolik 2021/11/7 11:21:00
#9 Posted: 2021/11/7 11:26:11
Tolik
Tolik
0 likes in 7 posts.
Thank you, Jean. You're right
I understand.
Because Lambda is calculated using three different formulas.
Interpolation is also needed.
But overall the solution looks right.
Best regards, Tolik
#10 Posted: 2021/11/7 12:25:28
Tolik
Tolik
0 likes in 7 posts.
Approximation in this case
#11 Posted: 2021/11/7 14:25:11
I understand.
Best regards, Tolik
Nothing wrong to adapt third segment for a smooth junction,
or simply ignore for elongating 2nd segment.
Take care ... Jean.
Inst_Colebrook PipeLine [unk].sm (24.9 KiB) downloaded 874 time(s).
Tolik 2021/11/8 18:22:00
#12 Posted: 2021/11/8 08:52:26
I understand.
Best regards, Tolik
I think you should initialize λ1:=64
Δp interpolation is straightforward as given.
λ interpolation will surely need Thiele.
Please, let me know if you want λ interpolation.
Have a good day Kamarad ... Jean.
#13 Posted: 2021/11/8 12:21:01
λinterpolation will surely need Thiele.
All your data sets have been converted to scalar functions.
Thiele is exceptional for Lambda.
By observation, Delta P needs better adjusting
segment 1 and segment 2 ... refine 2/3 junction.
All that done, it remains specific as demo, is it ?
Inst_Colebrook PipeLine [unk].sm (266.8 KiB) downloaded 895 time(s).
#14 Posted: 2021/11/8 14:08:11
... project refined for your comments.
Have a good visit ... Jean.
Inst_Colebrook PipeLine [unk].sm (267.71 KiB) downloaded 910 time(s).
#15 Posted: 2021/11/8 18:20:13
Tolik
Tolik
0 likes in 7 posts.
Sorry. I do not know the program well enough to properly evaluate your modifications and amendments.
You did a great job in my opinion.
In fact, the pressure will undergo two transitions.
The first transition: the destruction of the laminar flow and the appearance of the first large vortices.
The second transition: the core of the flow begins to touch the tops of the roughness of the pipe walls.
But I don't know exactly how they will affect the graph..
Yes, at this stage I needed to get a rough solution.
This is only the first section of the calculation of the system.
There are four of them.
Moreover, at the end, the pipeline has a branch. As a result, the solution is expected to be quite long.
Best regards, Tolik
#16 Posted: 2021/11/8 19:49:49
Best regards, Tolik
Perpendicular branches create singular losses.
Better conserve this refreshed version.
Nice project ... Jean.
Inst_Colebrook PipeLine [unk].sm (88.36 KiB) downloaded 915 time(s).
