numbers and vectors
numbers and vectors - Messages
#1 Posted: 2012/1/14 23:51:27
1,443 likes in 2,935 posts.
I think will be useful a function that show if a variabile it's a number (something like the classic isNaN() or also length(var) may be modified to return 0 or 1 in case var is a number)
regards
#2 Posted: 2012/1/15 02:41:11
I agree. As far as I know, there is only IsString() and IsDefined() functions among IsThisorThat() functions available. I believe that other functions like IsArray() or IsScalar() would be useful.
Regarding your question, IsString(arg) function will return 1 if the argument variable -arg- is string variable or function returning string, 0 otherwise (number, scalar, vector, matrix, function returning the ones).
#3 Posted: 2012/1/15 17:11:19
at the moment I'm using this workaround
Radovan Omorjan 2012/1/15 17:58:00
#4 Posted: 2012/1/15 18:07:35
There is a minor problem with your workaround. Suppose you have a matrix with only one element (this is allowed in SMath)
[MATH=eng]b←mat(5,1,1)[/MATH]
[MATH=eng]el(b,1)=5[/MATH]
[MATH=eng]el(b,1,1)=5[/MATH]
Your function will not recognize it as an array. It may cause problems sometimes, isn't it?
[MATH=eng]IsArray(b)=0[/MATH]
EDIT: On the other hand, every array is made by using mat() function i.e.
[MATH=eng]A←mat(1,2,1,3,2,2)[/MATH]
num2str( A )="mat(1,2,1,3,2,2)"
num2str( b )="mat(5,1,1)"
Unfortunately, I did not figure out how to use all of this to make a IsArray() function which will work with string, scalar and array arguments.
#5 Posted: 2012/1/15 20:35:05
with 1x1 vectors I don't have problems (I'm using SMath 0.90)
Now I've replaced
num2str(length())[/code] with less expensive [code]num2str()[/code] and I've replaced [code]findstr("l"[/code] with [code]findstr("m"
and I've fixed a little bug with words that contains the findstr argument and a big bug with strings with whitespaces introducing
IsString()
edit: here there is the file with the two functions IsArray.sm
#6 Posted: 2012/1/15 21:31:14
Thank you for your efforts. It is a bit tricky and unusual, but works most of the time. What do I mean by that. Just look at the picture (your function used) and it seems to be problematic for the arrays with units and nested arrays.
Maybe some more adjustments?
#7 Posted: 2012/1/15 23:15:48
This might be useful, I think.
EDIT: I just replaced the ans with this expression and it works as well with scalar and units (problem was with scalar and units including 'm in them)
ans:=findstr(_e,"mat("+1
#8 Posted: 2012/1/16 04:17:25
Great hints
