problem with "str2num"
problem with "str2num" - the function is not evaluated correctly - Messages
#1 Posted: 2019/6/17 13:36:00
127 likes in 342 posts.
I need to evaluate a condition (Boolean) that I have to build on a case-by-case basis. In testing this situation, I experienced the incorrect behavior of the "str2num" function in the case of the "=" sign.
str2number_z.sm (4.22 KiB) downloaded 1189 time(s).
#2 Posted: 2019/6/17 20:22:08
Clearly a bug it does not recognize 'Numeric'
#3 Posted: 2019/6/17 20:42:28
1,554 likes in 1,864 posts.
Try this.
sergio 2019/6/18 06:14:00, NDTM Amarasekera 2019/6/18 06:20:00
#4 Posted: 2019/6/18 05:36:23
thank you uni, it's a good buffer solution; only a minimum discomfort remains for entering the correct character.
