1 Pages (16 items)
[SS-2274] Save as XMCD - Messages
Worked for me. File attached.
Dimenzioniranje_GLULAM_2012-10-18.xmcd (90.37 KiB) downloaded 1352 time(s).
Thank you man! dont understand what the problem on mine side is
I think I can reproduce your issue. I can't test it on mathcad thus I need a feedback. The 1st attachment should works while the 2nd should be corrupted.
test_second.xmcd (90.37 KiB) downloaded 1218 time(s).
Hi, i have the same problem, anyone knows how repair the document?
WroteI think I can reproduce your issue. I can't test it on mathcad thus I need a feedback. The 1st attachment should works while the 2nd should be corrupted.
Yes, the first open with mathcad and the seccond fail... How u repair?
Thank you for the feedback!
I've already reported it as SS-2272.
The settings used by the plugin to save the XMCD file are your system settings (comma as decimal separator, when you get the error). Until a new version of the plugin will be available, you have to change your system settings before launching SMath and then you can save the file. Otherwise the file must be opened with a text editor and you have to fix the xml attributes.
Thanks for your help, but i change the system settings and the problem is still on. I hope the new version of the plugin be avaible soon to use the Smath with all computers in the job (i'm trying to convince my boss
See u soon guys, the program is excelent keep in that way!!
PD: The file is attached
You can try if this works... maybe there is another error...
P.S. just to be sure, for "system settings" I mean the OS settings (in Windows 7: Control Panel > Regional and Language Options > Formats > Additional settings)
Compuerta Desripiadora - Max.xmcd (76.41 KiB) downloaded 1216 time(s).
WroteYou can try if this works... maybe there is another error...
"OS settings"
Thanks!!!! The problem was solved, u rocks!
Hi people me again...
I have a new problem when i save as .xmcd
Attached image and document
Like always, thanks!
Compuerta Túnel - LH1 - 2 Hojas.sm (1.61 MiB) downloaded 32 time(s).
4 downloads and no reply... this is serious jejeje
Its an enormous sheet! Have you tried copying it to a new sheet piece by piece and saving to xmcd, until you found what section was causing that error?
Davide Carpi 2015/8/18 19:27:00
WroteIts an enormous sheet! Have you tried copying it to a new sheet piece by piece and saving to xmcd, until you found what section was causing that error?
Hehehe, I have been very busy in this sheet ... To find the error, I did yesterday the same like you (copy to a new piece by piece sheet and save XMCD), and the problem was edited image, when the delete the problem is resolved.
Now you know, dont edit images if you want to save XMCD.
Have a nice day, and thanks!
WroteNow you know, dont edit images if you want to save XMCD.
This is not completely true, seems the problem is just on the state of the images. If you uncheck the "edit" button everything goes fine.
Bug added in the BTS: SS-2274
Compuerta Túnel - LH1 - 2 Hojas_fixed.sm (1.6 MiB) downloaded 33 time(s).
1 Pages (16 items)
