About language selection
About language selection - Messages
#1 Posted: 2008/12/30 12:06:41
anis
anis
0 likes in 1 posts.
Hi. The default language is russian. How to change it to another language ?
#2 Posted: 2008/12/30 18:04:04
2,340 likes in 4,041 posts.
Hi. The default language is Russian. How to change it to another language ?
Hello.
Hmm. First time SMath Studio starts it chooses the interface language according to your Operating System settings. So, it's a little bit strange...
But, if it happens, than use following screens:
This screens are from new beta-version and if you use old 0.50.0-0.50.4 version I advise you to install the latest here.
#3 Posted: 2009/2/1 13:19:13
Wolf@smath
Wolf@smath
0 likes in 1 posts.
I had this problem, too. I just deleted all other (not wanted) language files in smath directory "lang". That works fine, too. Possible a easy method to write in a readme for distribution files ?
I'm just starting to work with this program, but it looks great. Until now I'm not sure how to work with it. I try to store some first samples in your forum if I solve it.
#4 Posted: 2009/3/10 20:00:13
rado
rado
0 likes in 2 posts.
In case developers are reading this forum, I ran into the same issue, and was able to fix thanks to your guide.
FYI: I'm using HTC Touch Diamond (Windows Mobile 6.1 Professional) with the locale and language set to Slovak. When I first launched SMath (version 0.78 build 3347) it was set to Bulgarian - possibly because SMath doesn't support Slovak. I think the default in these cases should be English.
Also, it appears to run a little slow on my device, but otherwise it is a fantastic calculator - I installed it mainly from nostalgia, to remember my university times. But that was a completely different age - I didn't even have a mobile phone then...
#5 Posted: 2009/3/10 22:12:54
Thanks for the information. I didn't knew that so many people has the same issue... will check/fix the default language then.
#6 Posted: 2009/3/11 00:08:31
That's it. Problem was localized and fixed. Next version will set English as the default language (in case, when yours system language is not available as interface lang).
#7 Posted: 2009/3/11 07:30:12
rado
rado
0 likes in 2 posts.
Cool, thanks for a quick fix!
