DotNumerics
DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - Messages
#21 Posted: 2018/8/1 12:54:24
1,554 likes in 1,864 posts.
Simple test 2.
DotNumerics.ode.test2.sm (21.23 KiB) downloaded 1542 time(s).
DotNumerics.ode.test2.pdf (79.99 KiB) downloaded 730 time(s).
sergio 2018/8/1 18:06:00, Radovan Omorjan 2018/8/2 03:05:00
#22 Posted: 2018/8/1 21:57:14
Simple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (24.51 KiB) downloaded 1606 time(s).
#23 Posted: 2018/9/9 14:23:36
1,355 likes in 2,271 posts.
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (23.66 KiB) downloaded 1690 time(s).
frapuano 2018/9/9 17:18:00, Вячеслав Мезенцев 2018/9/10 05:37:00
#24 Posted: 2018/9/10 06:48:25
Updated for SS 0.99.6824. Intervals issue fixed.
sergio 2018/9/10 07:02:00, frapuano 2018/9/10 09:23:00, NDTM Amarasekera 2018/9/10 09:48:00
#25 Posted: 2018/12/6 14:42:53
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
#26 Posted: 2018/12/24 09:13:53
Updated.
2018-12-24_17-06-48.png 2018-12-25_04-33-23.png 2018-12-25_04-34-24.png dn.ode.test2.png dn.ode.test1.png 2018-12-24_17-07-41.png
dn.ode.kinetic1.sm (8.26 KiB) downloaded 1768 time(s).
dn.ode.kinetic2.sm (12.59 KiB) downloaded 1652 time(s).
dn.ode.kinetic3.sm (12.28 KiB) downloaded 1709 time(s).
dn.ode.test1.sm (19.58 KiB) downloaded 1723 time(s).
dn.ode.test2.sm (18.88 KiB) downloaded 1680 time(s).
dn.ode.Amplitude detector.sm (20.17 KiB) downloaded 1746 time(s).
dn.ode.kinetic1.pdf (77.42 KiB) downloaded 955 time(s).
dn.ode.kinetic2.pdf (93.05 KiB) downloaded 895 time(s).
dn.ode.kinetic3.pdf (91.31 KiB) downloaded 876 time(s).
dn.ode.test1.pdf (115.72 KiB) downloaded 854 time(s).
dn.ode.test2.pdf (120.44 KiB) downloaded 851 time(s).
dn.ode.Amplitude detector.pdf (148.87 KiB) downloaded 884 time(s).
4 users liked this post
NDTM Amarasekera 2018/12/24 09:44:00, sergio 2018/12/24 11:04:00, frapuano 2018/12/24 14:23:00, Radovan Omorjan 2018/12/24 14:52:00
#27 Posted: 2018/12/25 14:49:08
Native works as well.
You can try rkfixedSteven.
#28 Posted: 2018/12/25 16:25:11
frapuano 2018/12/25 19:01:00
#29 Posted: 2021/12/9 09:10:25
SMath Studio compatibility
Plugin updated.
Changes:
- added support the mathematical form of the problem for ODE solvers;
- refactored.
sergio 2021/12/9 11:40:00
#30 Posted: 2021/12/20 16:18:13
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
#31 Posted: 2022/8/21 02:43:28
1,123 likes in 1,795 posts.
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (8.42 KiB) downloaded 1514 time(s).
#32 Posted: 2022/8/22 03:12:45
Plugin updated.
Changes:
- fixed values of initial conditions in the output array for dn_ImplicitRK5() and dn_ExplicitRK45().
sergio 2022/8/22 04:19:00, Alvaro 2022/8/23 20:15:00
