1 Pages (6 items)
Large Matrix Analysis - Messages
Dear All,
I am a civil engineer, specialized in water resources engineering.
My aim is to analyze 30 years of daily stream flow data in an Excel table with about 300 rows x 31 columns.
The data table contains negative values and strings which I have to discard first.
Then I want to create a column vector of data for further analysis.
The Smath program shown below gives the result, but takes a long time (about 50 seconds- see image).
As I build up the program for further analysis, the time grows up to even 5 minutes or more.
However, my Mathcad 15 program yields the result almost immediately.
Can anyone help to resolve this please? Thanks in advance.
ndtma
DailyQ_Malwala.xls (121.5 KiB) downloaded 779 time(s).
ndtma
Hello ndtma
I attach my proposal (approx. 25s on my notebook). The first part takes advantage from how are built matrices in SMath. The slower part is the 2nd (as for now I don't have ideas on how to improve this part).
[edit] please note that the first part is not strictly required, anyway seems to me (?) that there's a small speed improvement using a vector instead of the linear indexing on the matrix
![2015-04-29 10_41_14-SMath Studio Desktop - [Kalu Ganga-Malwala Operation Study-Simple-R1 (2).sm_].png](/zh-Hans-CN/files/Download/pzBGgy/2015-04-29-10_41_14-SMath-Studio-Desktop---[Kalu-Ganga-Malwala-Operation-Study-Simple-R1-(2).sm_].png)
NDTM Amarasekera 2015/4/29 05:50:00
Hello Davide
Thanks for your valuable proposal, and I am awaiting more improvements.
ndtma
ndtma
12s average (not immediate, however faster than the previous solution)
Kalu Ganga-Malwala Operation Study-Simple-R1 (1).sm (44.69 KiB) downloaded 1268 time(s).
Hello Davide
Thanks for the second improvement.
ndtma
ndtma
I was faced with a similar problem of a slow function (in fact EXCEL interop call). I could not speed up the function so I have created if() loops that will run the function only when input has changed. This makes sure that when workbook automatically recalculates it will not get "stuck" on a slow function unless necessary.
A sample is attached. In the workbook c:a+b is an example function, while a+b is input.
Hope that helps
input_CHK.sm (5.49 KiB) downloaded 1198 time(s).
Hope that helps
1 Pages (6 items)
