unit problem in matrices using max() function
unit problem in matrices using max() function - Messages
#1 Posted: 2012/2/9 05:53:34
vsandre
vsandre
0 likes in 8 posts.
If you want to get the highest value of a given Matrix you have to take care of the units.
1. all (tested) units should be the same
-> if not SMath should complain about unit mismatch
2. if the first value of a matrix is zero, the result does not contain any unit.
-> SMath should go to the first not zero element get its unit
