MathcadFileAccess
MathcadFileAccess - The following functions are useful for reading various file types into arrays. - Messages
#21 Posted: 2014/3/27 15:30:38
kilele
kilele
134 likes in 397 posts.
It has occurred to me that the plugin could send the bin data to the clipboard and then the user could make a paste (control-v) by hand into any folder (as the program HTMtied does)
Another alternative could be using DDE as a layer between windows programs, see:
http://jdde.pretty-tools.com/
http://www.thescarms.com/VBasic/ddeml.aspx
ioan92 2014/3/27 16:12:00
#22 Posted: 2014/3/27 19:42:35
kilele
kilele
have you tried to write to the %TEMP% or %APPDATA% directories ?
ioan92 2014/3/28 04:23:00
#23 Posted: 2014/3/28 03:25:09
1,355 likes in 2,271 posts.
Perhaps the function GetFolderPath() can help.
ioan92 2014/3/28 03:58:00
#24 Posted: 2014/3/28 06:00:10
kilele
kilele
Ioan, i'm not sure to understand the problem well
perhaps you can use DAvide's hyperlink plugin
ioan92 2014/3/28 06:22:00
#25 Posted: 2014/3/28 09:25:05
kilele
kilele
don't ask me why but i think that'll work if you place the sm files at the same directory as smath exe
ioan92 2014/3/28 11:57:00
#26 Posted: 2014/3/28 12:30:28
kilele
kilele
the two large buttons at the bottom are green in my case, tested with martin's portable version on xp
ioan92 2014/3/28 12:38:00
#27 Posted: 2014/4/24 18:15:34
1,554 likes in 1,864 posts.
Updated. Play() function now works as expected (it waits for the end of sound).
Davide Carpi 2014/4/24 19:22:00
#28 Posted: 2015/9/15 14:37:12
9_82abZ2
9_82abZ2
0 likes in 7 posts.
This is as good a place as any:
Is there a function that returns the filename of the current worksheet/Smath Document? I couldn't find it
#29 Posted: 2017/6/7 04:12:30
Martin_B
Martin_B
22 likes in 84 posts.
Currently I have the same question and also no answer (and couldn't find one).
Can anybody help?
#30 Posted: 2017/6/7 15:20:56
Is there a function that returns the filename of the current worksheet/Smath Document?I couldn't find it
Simple but not so simple, EXPLAIN:
1. If your work sheet resides in a subfolder: don't know if possible [didn't find trick]
2. If your work sheet reside in a folder in "C:\ ==> like this
path:=CurrentDirectory("")
path="C:\Smath6179\"
#31 Posted: 2017/6/7 21:42:05
#32 Posted: 2017/6/8 03:16:49
Martin_B
Martin_B
Hi Jean,
I do know 'CurrentDirectory( "" )' but it returns the path without the filename. And I am trying to retrieve the latter.
#33 Posted: 2017/6/8 08:38:18
If I open a work sheet from "My Computer, C, click on the Folder, click on the work sheet
it will open Smath and CWD= is from which folder the work sheet comes from [Snippet].
Differently, If I open Smath first from the task bar, and click on the file name from the
file list on the Smath menu, I get: CWD="C\Program Flies\Smath Studio"
In fact, my Smath is so simple ... all my 925 work sheets are piled in Smath6179 folder.
All in all => same as Mathcad 11
#34 Posted: 2017/6/8 09:05:42
Can anybody help?
As workaround you can use simple C# script for this (Script plugin).
store.AddDefinition( terms[0].Text, new Term[0], new Entry( "\"" + store.FileName + "\"" ) );
#35 Posted: 2017/6/8 11:46:34
A more complete code would look like Mathcad 11
CWD="C:\Program Files\Mathsoft\Mathcad 11\Handbooks\datapack"
#36 Posted: 2019/10/29 05:05:48
The function getfolderpath() seems to be broken for build 7219:
getfolder.sm (2.21 KiB) downloaded 1568 time(s).
Show Spoiler
#37 Posted: 2019/10/31 14:05:49
Updated and rebuilded for SMath Studio ≥ 0.99.7109.
Martin Kraska 2019/10/31 20:00:00, sergio 2019/11/2 14:46:00
#38 Posted: 2021/6/29 08:08:28
Oscar Campo
Oscar Campo
135 likes in 309 posts.
I found that the following functions of this plugin are not working:
Play(), WRITEWAV(), GETWAVINFO(), READWAV().
I saw the problem inside the interactive SMath Handbook.
I have SMath Studio 0.99.7822 (01 June 2021) on win10.
Oscar
#39 Posted: 2021/6/29 09:47:38
SMath Studio compatibility
Plugin updated. Please try.
Changes:
- plug-in corrected to respect latest SMath Studio API changes.
Oscar Campo 2021/6/29 10:15:00, sergio 2021/6/29 11:55:00
