[SS-2286] Imperial unit system issue
[SS-2286] Imperial unit system issue - Unit issue with unit system set to Imperial - Messages
#1 Posted: 2018/4/13 16:08:37
Engr
Engr
8 likes in 24 posts.
I have an issue with imperial units in a calculation not canceling each other out. When the unit system is set to Metric the imperial units cancel out which results in an unitless number. Which is what is desired in my calculation. However, because I want the entire calculation page to be in Imperial units, I switched the OutputUnitsSystem to equal Imperial. The same calculation now displays a very uncommon set of units. The display units should actually cancel out and display a unitless number.
I have tried "Ignore units" but nothing seems to change. Is there anyway to get around this and not change the unit system back to Metric.
Some help would be appreciated.
#2 Posted: 2018/4/13 16:31:11
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
Using settings.inf equal to Imperial is buggy and documented. Best using SI for settings.ini
