1 Pages (4 items)
UPDATED: SMath Studio 0.98.6047 (22 July 2016) - Messages
SMath Studio 0.98.6047 available
Latest changes (against SMath Studio 0.98.5997)
- Updating of Scrollbar Bookmarks fixed on region Delete and Undo/Redo operations;
- Performance significantly increased when opening worksheets (invisible Regions do not call for invalidation of the worksheet anymore);
- SS-2325: Scrollbars related multithreading issue appeared sometimes when working with scrollbars fixed;
- Initial implementation of the built-in debugging tools completed (set breakpoint [Ctrl+F8 or context menu] and recalculate a worksheet);
- Pause button is available on main toolbar now - it allows to pause calculation and see an exact place where calculation is in progress;
- Plug-in name included into the Tooltip for functions/variables/operators;
- Arctan2() function implemented (see known issues below).
Updated 22 July:
- All breakpoints shown on the vertical scrollbar now, even if they are all in the same region;
- Issue regarding plug-ins back-compatibility related to debugging fixed;
- Context Menu with Copy button implemented for the list in Watch panel;
- Fixed issue when unwanted selection appeared sometimes on debugging;
- Errors appeared during calculation immediately displayed on vertical Scrollbar now.
Updated 24 July:
- Tooltips implemented for items in Watch panel;
- Calculation logic improved for better support of existing worksheets created by previous SMath Studio versions;
- Critical issue fixed appears on opening Dynamic Assistance list without any Evaluable Region before the cursor;
- Plug-ins related back-compatibility issue fixed.
Known issues
- Debugging: Hotkeys for debugging not assigned yet (except Ctrl+F8 for toggling breakpoints);
- Debugging: Breakpoints set on numbers may not work;
- Calculation: Function atan(2) has couple of issues;
- Backcompatibility: Some of the worksheets will not be correctly recalculated still (issue related to undefined variables in definitions).
- Interface translation: Some strings is not translated yet (they even not registered in translation service).
Download
SMathStudioDesktop.0_98_6049.Setup.msi (Date: 24.07.2016. File size: 2.03MB) - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_98_6049.Mono.tar.gz (Date: 24.07.2016. File size: 1.17MB) - last version of Mono distributive required! Cloud version(all modern browsers supported):
SMath Studio in the Cloud (Date: 02.06.2016.)
9 users liked this post
NDTM Amarasekera 2016/7/22 01:51:00, Radovan Omorjan 2016/7/22 03:29:00, sergio 2016/7/22 05:29:00, Igor Skarine 2016/7/23 19:17:00, Mike Kaganski 2016/7/22 05:39:00, Davide Carpi 2016/7/22 05:51:00, Peter 2016/7/22 07:01:00, frapuano 2016/7/22 07:59:00, уни 2016/7/21 23:50:00
Updated with new links to the corrected build (plug-ins back-compatibility fixed).
4 users liked this post
sergio 2016/7/22 17:28:00, NDTM Amarasekera 2016/7/22 23:18:00, уни 2016/7/23 02:40:00, Davide Carpi 2016/7/23 04:44:00
Updated with new links to the corrected build. Plug-ins back-compatibility fixed: http://en.smath.info/forum/yaf_postst7662_Error--Unable-to-import-XLSX-data-file-in-SS-98-6047.aspx
NDTM Amarasekera 2016/7/24 22:59:00, Вячеслав Мезенцев 2016/7/25 01:15:00, Davide Carpi 2016/7/25 04:31:00
WroteIf I would like to upload a worksheet, how this can be done?.
Example: in the conference "Questions" click on "New topic"
that will bring the line menu up there,
click on "trombone symbol" ... upload a new file,
double click in the work sheet in your system.
Finally, click on "Upload", then "Post" below.
You can proceed same way in any of the conference [Samples, Bugs ...]
Cheers, Jean
1 Pages (4 items)
