1 Pages (6 items)
Vector Variable - Display a vector variable - Messages
Can I have a variable be displayed as boldface or with an arrow above, to display a vector variable v (scalar) v (vector), or phasor, etc. ?
Thank you,
Basile
Thank you,
Basile
Greetings,
Bold face:
Related forums:
[/list]
May this be of Good Help;
-Kenny Lemens, P.E. ᵂᴵ
Bold face:
- Can take advantage of 'Absolute Definitions,' they behave like a variable, but are evaluated an order before a standard variable.
To use, type the 「~」 character, and then your variable name. You can copy and paste the following:~v:#[/code][/list] [u]Arrows 'above':[/u] [list][*]If you want an arrow above, you can copy/paste the following: [list][*][code=markup]v⃑:# v⃗:#
- https://en.smath.com/forum/yaf_postst23318_Arrows-bei-Vectors.aspx
- https://en.smath.com/forum/yaf_postst23323_-ready-Vector-arrow.aspx
[/list]
Hello Kenny,
1. Is there an easy way to enter the arrow above the letter?
2. How I can enter a hat (unit vector) above a letter?
Thanks,
Basile
Thanks,
Basile
Greetings,
Wrote1. Is there an easy way to enter the arrow above the letter?
Not that I am aware of; I did write code to accomplish this (reference forum: https://en.smath.com/forum/yaf_postsm79999_SMath-Keyboard-Shortcuts.aspx#post79999), but I didn't deploy it as an plugin.
As for a native solution, I have a txt file with these special characters that I just copy/paste (apparently copy/paste from a browser isn't reliable for these special characters, hence the standalone txt file):
SpecialChar_Combine.txt (74 B) downloaded 1027 time(s).
Another solution is to utilize EnableHexNumpad on your keyboard and enter the hex code manually for these characters (but you could easily download a 3rd party application that allows you to assigns hotkeys to insert these special characters as well.
Wrote2. How I can enter a hat (unit vector) above a letter?
See the attached txt file above (or the url link; the keyboard shortcut list will provide you the hex code under Formatting Math Region (top of page 3).
1 Pages (6 items)
