Ideas for further plugins
Ideas for further plugins - Ideas and resources about possible plugin improvements - Messages
#61 Posted: 2023/5/22 07:59:06
Add trapeze integrator to rescue the built-in Simpson as it fails.
Unlimited use per document, each independent 'n'.
#62 Posted: 2023/5/23 23:36:49
Mark R Harris
Mark R Harris
4 likes in 90 posts.
The image region plugin works well for SVGs, thank you.
Unfortunately, when 'saved as' a PDF they are rendered out as rasters (not very good ones).
#63 Posted: 2026/2/12 15:55:40
Alex Fernando Guadalupe rojas
0 likes in 1 posts.
It could be interesting to implement a plugin that allows me to mark a variable located anywhere on my sheet and monitor its value while I change another variable elsewhere. For example, when designing, approval values are often at the end, while the main input is at the beginning. Every time I need to see how a change affects the variable of interest, I have to scroll all the way down to check it, which makes the process very tedious.
#64 Posted: 2026/2/12 16:31:07
127 likes in 342 posts.
(#63) Alex,
For now, you can use the trace() command and launch the debug window with F11.
ioan92 2026/2/15 13:08:55, Davide Carpi 2026/2/12 19:01:57
#65 Posted: 2026/2/12 19:01:41
1,443 likes in 2,935 posts.
There was also the split-window Mode, once upon a time.
However, another way could be the use of absolute variables (those that have a leading tilde character in the name).
Define ~abs_variable_name:variable_name after your actual calculation, then put the evaluation of ~abs_variable_name wherever is best for you.
Edited 2026/2/12 19:31:59
sergio 2026/2/12 19:50:45
#66 Posted: 2026/2/13 12:35:57
1,355 likes in 2,271 posts.
This is also an option. It avoids absolute variables, which are a nightmare to type with a german keyboard.
Yet it relies on double recalculation after changes in input.
sergio 2026/2/13 17:20:59, Davide Carpi 2026/2/13 18:42:26
#67 Posted: 2026/2/13 22:38:11
598 likes in 1,380 posts.
What I would like some already existing plugins support Linux Mono, not just Windows.
Edited 2026/2/13 22:38:26
