Ideas for further plugins
Ideas for further plugins - Ideas and resources about possible plugin improvements - Сообщения
#61 Опубликовано: 22.05.2023 07:59:06
Add trapeze integrator to rescue the built-in Simpson as it fails.
Unlimited use per document, each independent 'n'.
#62 Опубликовано: 23.05.2023 23:36:49
Mark R Harris
Mark R Harris
4 сообщений из 90 понравились пользователям.
The image region plugin works well for SVGs, thank you.
Unfortunately, when 'saved as' a PDF they are rendered out as rasters (not very good ones).
#63 Опубликовано: 12.02.2026 15:55:40
Alex Fernando Guadalupe rojas
It could be interesting to implement a plugin that allows me to mark a variable located anywhere on my sheet and monitor its value while I change another variable elsewhere. For example, when designing, approval values are often at the end, while the main input is at the beginning. Every time I need to see how a change affects the variable of interest, I have to scroll all the way down to check it, which makes the process very tedious.
#64 Опубликовано: 12.02.2026 16:31:07
(#63) Alex,
For now, you can use the trace() command and launch the debug window with F11.
ioan92 15.02.2026 13:08:55, Davide Carpi 12.02.2026 19:01:57
#65 Опубликовано: 12.02.2026 19:01:41
There was also the split-window Mode, once upon a time.
However, another way could be the use of absolute variables (those that have a leading tilde character in the name).
Define ~abs_variable_name:variable_name after your actual calculation, then put the evaluation of ~abs_variable_name wherever is best for you.
Отредактировано 12.02.2026 19:31:59
sergio 12.02.2026 19:50:45
#66 Опубликовано: 13.02.2026 12:35:57
This is also an option. It avoids absolute variables, which are a nightmare to type with a german keyboard.
Yet it relies on double recalculation after changes in input.
sergio 13.02.2026 17:20:59, Davide Carpi 13.02.2026 18:42:26
#67 Опубликовано: 13.02.2026 22:38:11
599 сообщений из 1 380 понравились пользователям.
What I would like some already existing plugins support Linux Mono, not just Windows.
Отредактировано 13.02.2026 22:38:26
usamakhan 17.10.2026 05:03:49
