How to use the solve function in this task
How to use the solve function in this task - Messages
#1 Posted: 2024/6/2 20:33:38
Valery Ochkov
Valery Ochkov
66 likes in 690 posts.
3-2-CoolProp-Solve.sm (46.14 KiB) downloaded 1430 time(s).
#2 Posted: 2024/6/2 22:24:24
ioan92
ioan92
180 likes in 120 posts.
Take care :
Your CoolProp function, as you write it, does not change the sign, between the two limits of the variable p :
Valery Ochkov 2024/6/2 23:27:00
#3 Posted: 2024/6/2 23:27:35
Valery Ochkov
Valery Ochkov
Thanks,
send please the sm-file with the solution
#4 Posted: 2024/6/3 00:42:55
ioan92
ioan92
The problem, as you formulated, seems as not having a solution in real numbers, in order to be solved with the solve routine.
I'm sorry but I have no time to reformulate your problem.
If you intend to solve it numerically, try to check the continuity of the function and the fact that in the range you look for solution there is at least one change of the function value sign.
Valery Ochkov 2024/6/3 00:59:00
#5 Posted: 2024/6/3 01:46:02
1,355 likes in 2,271 posts.
The problem as stated in the opening post, actually has a solution in the given range.
Yet, I don't see an alternative to using brute force to tame the coolprop function: sampling and interpolation.
Valery Ochkov 2024/6/3 01:50:00
#6 Posted: 2024/6/3 02:12:41
1,123 likes in 1,795 posts.
Hi. The guess values, in this case the range, are part of the solution, this means that you must know where the numerical procedure works fine. In this case the interval 1 MPa ... 6 MPa.
3-2-CoolProp-Solve.sm (49.75 KiB) downloaded 1411 time(s).
#7 Posted: 2024/6/3 10:47:51
Valery Ochkov
Valery Ochkov
Thanks, Martin and Alvaro
See please the problem in attach
Fireless-Locomotive.sm (882.15 KiB) downloaded 1428 time(s).
PS
Alvaro!
And what about the book?
#8 Posted: 2024/6/3 12:58:22
Hi Valery. This could be an option.
Fireless-Locomotive.sm (915.8 KiB) downloaded 1430 time(s).
PS
Alvaro!
I'm pretty busy right now! Sorry.
Valery Ochkov 2024/6/3 16:04:00
#9 Posted: 2024/6/3 16:29:42
Valery Ochkov
Valery Ochkov
It works! By p.0=240 atm
Fireless-Locomotive.sm (882.15 KiB) downloaded 1499 time(s).
But by p.0=140 atm ---???
Alvaro>
Check please 1-2-3 chapters.
My student from Cuba is waiting for it!
#10 Posted: 2024/6/5 21:16:15
... Check please 1-2-3 chapters.
Hi Valery. I find it quite inappropriate that what is a voluntary collaboration helping on regarding a translation, and therefore supposedly free of commitment on both sides, is publicly claimed in the forum. This situation seems to reflect some type of irresponsibility on my part as I am failing to make some type of commitment, which, I insist, there is none. I would sincerely like to receive some kind of explanation as to why you are making a public complaint about a translation job on my part when there is no agreed commitment.
#11 Posted: 2024/6/5 23:25:56
Valery Ochkov
Valery Ochkov
Please forgive me, of course I'm wrong.
Val
#12 Posted: 2024/6/6 00:18:58
Of course. He is already forgotten.
