modifying tables
modifying tables - Messages
#21 Posted: 2019/5/15 11:51:53
Can you make a table in one SMath file, and have a calculation in another SMath file refer to the table in a calculation?
SS 6179 does not save Table in file.
Differently, a matrix data result does save and is lot more technical.
#22 Posted: 2019/5/15 12:25:46
The Cross
The Cross
0 likes in 73 posts.
How do I reference a matrix in another file?
#23 Posted: 2019/5/15 12:48:51
127 likes in 342 posts.
you can check the features of the "include" plugin
#24 Posted: 2019/5/15 20:44:12
PipeData is spooled to file from where it is created,
then recovered from wherever.
It should create SmathFile in your C:\ root directory.
If not => create it
Inst_Colebrook Pipe Data_Recover.sm (4.92 KiB) downloaded 1113 time(s).
Inst_Colebrook Pipe Data.sm (59.42 KiB) downloaded 1081 time(s).
#25 Posted: 2019/5/17 15:09:56
The Cross
The Cross
Why is SMath not recognizing the Matrix callout?table1.sm (13.72 KiB) downloaded 1054 time(s).
#26 Posted: 2019/5/17 19:53:18
Table is a local decorative gadget, thus: not a matrix as such.
Disambiguate: Smath spools to file a Matrix but not a Table.
#27 Posted: 2021/1/9 16:19:40
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
@Britt1,
Did you get this to work? On my list of things to torture myself with. I have a spreadsheet for this, but like keeping everything, when reasonably possible, on one platform. Moving hard to QC spreadsheets to SMath is interesting to say the least . This has been on the back-burner as it's easy to check. I actually think this will be more complicated in SMath than it's worth, thus asking if you got something to look at
#28 Posted: 2021/1/9 16:56:43
598 likes in 1,380 posts.
@Britt1,
Maybe I understood completely wrong what you are trying to do.
But I have just deleted FU and rewrote it.
The operand was # in your example, what it means?
        <input>
          <e type="operand">FU</e>
          <e type="operand">#</e>
          <e type="operator" args="2">:</e>
        </input>
