Problem with animated gif from plot region
Problem with animated gif from plot region - Gif doesn't show a smooth animation, seems to have sequence errors - Messages
#1 Posted: 2021/12/4 20:10:32
1,355 likes in 2,271 posts.
In interactive mode, the animation is smooth and shows the correct colors.
Federpendel - Kopie.sm (48.94 KiB) downloaded 1445 time(s).
This was generated with latest SMath Solver, many sequence errors, wrong colors (dot is not red)
This was generated using build 6884, has still some glitches but much better.
Show Spoiler
#2 Posted: 2021/12/7 09:13:54
1,123 likes in 1,795 posts.
Hi Martin. This is a workaround. Sselect the plot and another area, for example k: range (1, n), which is above the plot. Export the animation. Then, for some reason, it asks twice for the filename. The result does not preserve the color, but at least it seems that does not lose frames.
