Maxima error - draw2d
Maxima error - draw2d - Earlier posted fit.sm gives error - Messages
#1 Posted: 2021/7/15 12:49:18
timgow
timgow
0 likes in 27 posts.
I'm importing digitised graph data and wish to use a curve fit function. I have found only the Maxima 'Fit()' function, with reference to mkraska's file fit.sm (thank you mkraska).
https://en.smath.com/forum/yaf_postst7475_Curve-fit-function.aspx
I get an error when I open this file in my installation. I have installed maxima-5.45.1-win64.exe in a subdirectory in the Smath installation location.
Please see the error in the image attached.
Does this point to a known problem?
All help is much appreciated.
#2 Posted: 2021/7/15 13:45:20
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
My file opens without error
Fit1.sm (15.26 KiB) downloaded 1097 time(s).
#3 Posted: 2021/7/15 13:57:29
timgow
timgow
I have shutdown and reopened and the Draw2d error has disappeared.
In mkraska's example, a result could be produced for L:=()= but mine can't "A - not defined", any ideas why this would be?
#4 Posted: 2021/7/15 13:59:13
timgow
timgow
Ber7, thank you for checking for me, not sure why now ok.
#5 Posted: 2021/7/15 15:54:17
I'm importing digitized graph data and wish to use a curve fit function
1. Cholesky is the first classroom.
Rarely useful as very few physical phenomenons are poly type.
You can trick the exponents of the monomials.
2. Next is Padé rational fraction... needs lot more data points.
3. Else are model function [imagination is the limit].
That is a season Classroom !
The core component is Cholesky in Conjugate Gradient.
#6 Posted: 2021/7/15 16:39:39
timgow
timgow
Jean,
Thank you for the illustration of Cholesky. My property curves are well behaved as in your example so I'm sure that this will be ok.
Much appreciated,
Tim
#7 Posted: 2021/7/15 17:09:30
1,355 likes in 2,271 posts.
You have to switch to optimization none in the context menu. The result of Fit() is displayed as list of equations name=value. If you try to numerically evaluate this, then you get the error that A isn't defined.
Assign() converts the equations into assigments, so that further down the variables have numerical values.
#8 Posted: 2021/7/15 17:20:56
Jean,
Much appreciated,
Tim
Your data set is OK, compatible to poly 3.
More visit c/w error bar.
Thanks for your appreciation ... Cheers ... Jean
Poly 0 Read First Edu.sm (37.07 KiB) downloaded 1056 time(s).
Genfit Kirby_2 [Reduced] Copy.sm (81.39 KiB) downloaded 927 time(s).
Genfit Rational Type J_8 Copy.sm (65.8 KiB) downloaded 1031 time(s).
