1 Pages (8 items)
Function from plot - Messages
WroteHow can I get a function from this plot ?
1. Probably from the expensive digitizer suggested by Richard [Mathsoft Collaboratory]
2. Piecewise from Tracer.
3. Try Mathsoft digitizer.
4. Smath difficult
At this point from the collected data set, fit a model function.
Valery Ochkov 2023/6/6 10:24:00
Greetings,
That is a straight line on a semi-log graph; you can reference this handout: https://inside.mines.edu/~epoeter/_GW/LAB/EquationsOfStraightLinesOnDifferentTypesGraphPaper.pdf
Per this handout, your equation should be where:
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
WroteHow can I get a function from this plot? 🖼
y = b + m*log(x)
- m = difference in y over one log cycle of x
- b = y value corresponding to x=1
Hi. You can try this post Approximation of a functional curve in a digital image or this other one: Embedding images into a plot
Hello Valery,
some Smath digitizing utilities
Cheers, Jean.
Digitize Tracer 15.sm (28.83 KiB) downloaded 1191 time(s).
Digitize OVNI Copy.sm (69.15 KiB) downloaded 1189 time(s).
Digitize Contour Isocurve Himmelblau Copy.sm (106.67 KiB) downloaded 1242 time(s).
Digitize Curve.sm (295.86 KiB) downloaded 1182 time(s).
Digitize Contour.sm (829.05 KiB) downloaded 1253 time(s).
Digitize Clean_Strip_Smooth.sm (1.76 MiB) downloaded 1270 time(s).
... this Himmelblau has resident Gray matrix.
Digitize Contour Isocurve Himmelblau Copy.sm (107.19 KiB) downloaded 1228 time(s).
Valery Ochkov 2023/6/7 01:02:00
Hi. Hope this helps.
Modeling a functional curve in a digital image.pdf (860.39 KiB) downloaded 761 time(s).
Modeling a functional curve in a digital image.sm (1 MiB) downloaded 1306 time(s).
1 Pages (8 items)
