[Nonlinear solver] Vectorize Operator and Symbolic Optimization in SS 6179
[Nonlinear solver] Vectorize Operator and Symbolic Optimization in SS 6179 - Messages
#1 Posted: 2017/2/3 05:34:27
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
The attached image shows different results in symbolic optimization in using Vetorize Operator, and
consequently generates an error when using "FindRoot" function in the attached worksheet.
When Equations 1B & 2B are disabled and 1A & 2A enabled, "FindRoot" gives the result.
Vectorize error - Symbolic Optimization.sm (189.05 KiB) downloaded 1149 time(s).
#2 Posted: 2017/2/3 06:07:35
127 likes in 342 posts.
if you initialize the vector Q, then it works
Q:mat(el(Q,1),el(Q,2),el(Q,3),el(Q,4),4,1)
Davide Carpi 2017/2/3 07:26:00, NDTM Amarasekera 2017/2/3 11:20:00
#3 Posted: 2017/2/3 06:42:52
NDTM Amarasekera
NDTM Amarasekera
Thank you! It works.
#4 Posted: 2017/2/3 12:11:43
Your red vectorise is just a display, i.e: not an assignment.
Unlike the "red vectorise", the "blue vectorise" ASSIGNS the
vector required by FindRoots, thus immaterial wrt Symbolic/Numeric/NONE
The suggestion to initialise is not technical to me [just a comment].
It simply confuses matters. There is a long route to explore/clarify
the Smath Vectorise operator
