FUNCTION MATRIX ADR SHEET
FUNCTION MATRIX ADR SHEET - Need help manipulating the matrix - Messages
#1 Posted: 2021/1/9 19:19:46
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
Some direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix.ADR.sm (127.5 KiB) downloaded 1036 time(s).
Thank you
#2 Posted: 2021/1/9 22:34:24
Quick brute force for a range of values, AFAIU.
Cheers old Collab Elsid ... Jean
ADR brute force.sm (150.39 KiB) downloaded 1046 time(s).
#3 Posted: 2021/1/10 01:02:58
... here is a more complete search.
ADR brute force augmented.sm (159.59 KiB) downloaded 1021 time(s).
#4 Posted: 2021/1/10 21:17:49
Don't miss the Truth Table Companion in Samples.
#5 Posted: 2021/1/10 23:16:00
598 likes in 1,380 posts.
Aaah now I get what you meant.
This should solve your problem.
Deleted previous post.
#6 Posted: 2021/1/11 12:56:03
Ruben Sidranski
Ruben Sidranski
Is this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you
#7 Posted: 2021/1/11 13:25:58
InterpBilinear() is in the 'Custom Functions' plugin.
Basically an interpolation with two variable.
Good and useful function.
#8 Posted: 2021/1/11 14:09:54
... from the attached example,
get inspired to construct the data ready for matrix interpolation.
Elsid Spline Table.sm (19.1 KiB) downloaded 1033 time(s).
