1 Pages (3 items)
Opertion problem or user error? - Messages
hi-
I was a bit bored at work today so I started playing around with an air pressure/altitude formula. Formula works fine and gives me the correct result, but when I add in the units I get an error "Operation cannot be performed with units". Pretty sure it's most likely a user error, but can someone explainAir Pressure at Altitude.sm (8.88 KiB) downloaded 980 time(s). this to me?
thanks
thanks
Wrotecan someone explain
You calculate pressure vs altitude from a theoretical invalid book formula.
Above your head [mine too !] is not homogeneous and can't be represented by a single formula.
The worst of that fact is that the discontinuity is sensibly around 11 km. That's why airplanes
tend to fly above or below that altitude in best agreement with the air-trafic assigned corridor.
In short: Atmosphere is only tabulated [OIAC, ISA, PDAS]
PDAS is from Ralph Charmichael, the most recognized.
We agree that that actual 'P' could be corrected vs 'km' altitude from estimate. and more parameters.
That correction, I have never seen any proposed correction.
For practical use, you may use some of the formulas-approximations in the attached.
Those things, you will find nowhere else ... Why ?
Advanced CAS like Smath, Mathcad ... are above the head of the old style Techocrates.
Something like Lagrange refused Fourier works up until Lagrange passed away.
Please, do not hesitate for more questions.
In those documents, you will find the link to PDAS Ralph web site.
Inst_ISA [kPa].sm (14.1 KiB) downloaded 785 time(s).
Inst_ISA.sm (141.53 KiB) downloaded 1006 time(s).
Inst_ISA Altitude vs Pressure.sm (77.3 KiB) downloaded 991 time(s).
1 Pages (3 items)
