Convert TNumber in VB .net plug-in
Convert TNumber in VB .net plug-in - Is it possible to convert TNumber to Single or Double? - Messages
#1 Posted: 2021/7/21 11:52:42
Engr
Engr
8 likes in 24 posts.
I have a previous VB subroutine (with a iterative mathematical calculation) which I would like to put into a plug-in for use with SMath Studio. I have started with the VB.net plug-in template and have a function started which passes the starting values from a smath worksheet to the plug-in. I have gotten so far as the values from the worksheet are transfered to the plug-in as TNumber objects. I need to convert the values from TNumber to Single or Double VB numbers to pass them to the subroutine (the subroutine uses single and doubles in the calculations). Is there a way to convert between TNumber and Single or double and then back again in VB code?
Thanks,
Engr
#2 Posted: 2021/7/21 14:41:03
1,532 likes in 1,838 posts.
I recommend making a copy of the repository on a local disk and then looking for code examples in it.
Also, right in the program there is a user's guide (or Core documentation).
[TNumber].obj.ToDouble() - convert to double
New TNumber( double, double ) or CType( double, TNumber ) - for back operation, but I'm not sure how it will look in basic. There is an implicit conversion operator.
Engr 2021/7/27 11:05:00
#3 Posted: 2021/7/27 11:04:22
Engr
Engr
Uni,
Thanks for the reply and the tips for finding information.
I hope you can help with one more item I am struggling with. I am able to return a double with the solution from my calculation subroutine back to the SMath worksheet with the following:
Dim force as Double
result = New Entry( force )
However I would like to return four values to SMath instead of just one. Is it possible to have a single function in a plug-in return a 4x1 matrix to SMath?
I appreciate the assistance.
Engr
