appimage in Debian (MX Linux)
appimage in Debian (MX Linux) - doesn't work - Messages
#1 Posted: 2025/2/21 19:41:44
bambuko
bambuko
0 likes in 6 posts.
I have seen a lot of discussion here about problems with using SMath with Mint and Ubuntu,
but nobody mentioned my distro:
MX-23.5_KDE_x64 Libretto
I have downloaded appimage, made it executable and here is the result:
Quote
bambuko@mx-elitedesk:~/Applications/SMath_Studio
$ ./SMathStudioDesktop.1_3_0_9126.x86_64.ubuntu-22_04.glibc2.35.AppImage
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Drawing.Printing.SysPrn' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdiplusStartup(ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x000d4] in <728fbd68fe594062895e1f819791e76a>:0
--- End of inner exception stack trace ---
at System.Drawing.Printing.SysPrn..cctor () [0x00000] in <728fbd68fe594062895e1f819791e76a>:0
at System.Drawing.Printing.PrinterSettings..ctor () [0x00000] in <728fbd68fe594062895e1f819791e76a>:0
at System.Drawing.Printing.PrintDocument..ctor () [0x00011] in <728fbd68fe594062895e1f819791e76a>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Printing.PrintDocument..ctor()
at SMath.Environment.DesktopAppEnv..ctor (System.String appNameInternational, System.String appNameLocal, System.Version appVersion, System.Boolean isWebApplication, System.String applicationPath, System.Boolean randomizeInstallationId) [0x00019] in <9ea83db511ca44e3bef101076f6663b2>:0
at SMath.Environment.DesktopAppEnv..ctor (System.String appNameInternational, System.String appNameLocal, System.Type appType, System.Boolean isWebApplication, System.String applicationPath, System.Boolean randomizeInstallationId) [0x00013] in <9ea83db511ca44e3bef101076f6663b2>:0
at SMath.Environment.AppSettingsDesktop.SetupGlobalProfile (System.String appNameInternational, System.String appNameLocal, System.Type appType, System.Boolean randomizeInstallationId) [0x00000] in <9ea83db511ca44e3bef101076f6663b2>:0
at .. (System.String[] ) [0x0001d] in :0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Drawing.Printing.SysPrn' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
Restoring environment...
Can anybody help, please?
#2 Posted: 2025/2/22 07:19:21
598 likes in 1,380 posts.
Try file from this post, it works on mint and ubuntu.
I made a couple of corrections for this appimage.
Maybe it works for your distro too.
https://en.smath.com/forum/yaf_postsm86402_AppImage-File-Crashes-on-Linux-Mint-v22.aspx#post86402
#3 Posted: 2025/2/22 08:04:45
bambuko
bambuko
0 likes in 6 posts.
I have tried it before posting...
unfortunstely, no it doesn't work
#4 Posted: 2025/2/22 18:23:05
Then I will download liveiso of your distro.
And I will try smath on it with qemu.
Please standby...
#5 Posted: 2025/2/22 18:34:37
bambuko
bambuko
0 likes in 6 posts.
Thank you,
hopefully we can get it working with Flatpak.
I am using Smath with https://usebottles.com/ at the moment but would prefer to avoid this complication....
#6 Posted: 2025/2/22 18:55:34
Thank you,
Probably, why it doesn't work is glibc/libgdiplus mismatch.
I will look further but most times problem is this.
#7 Posted: 2025/2/22 19:11:06
I did install mono-devel, libgdiplus and download mono package.
I extracted it and tried to run but it gives errors.
No wonder why appimage not working, mono executable doesn't work too.
#8 Posted: 2025/2/22 19:58:31
bambuko
bambuko
0 likes in 6 posts.
Yes, I know all these error messages :-)
thank you
#9 Posted: 2025/2/22 20:04:12
bambuko
bambuko
0 likes in 6 posts.
BTW there is another annoying problem with forum software as it is at the moment.
Email notices about your post give the following link:
http://en.smath.com/forum/yaf_postsm86558_appimage-in-Debian--MX-Linux.aspx#post86558
trying to use it leads to nowhere...
it should be:
https://en.smath.com/forum/yaf_postsm86558_appimage-in-Debian--MX-Linux.aspx#post86558
the same goes for SMath webpage - all the links there are also http instead of https.....
I guess it might also be to do with the way my browser is set?
#10 Posted: 2025/2/23 18:18:08
Sorry to say I couldn't make it work.
I tried stable/nightly versions of mono.
Neither appimage or smath mono works on debian.
Only thing I didn't try is full recompile of mono.
As I have said many times;
Debian and/or its derivatives are not suitable for desktop usage.
#11 Posted: 2025/2/23 18:35:16
bambuko
bambuko
0 likes in 6 posts.
Thank you for trying.
