Program for Linear and Polynomial Fit
Program for Linear and Polynomial Fit - Messages
#21 Posted: 2019/12/11 13:31:21
Martin_B
Martin_B
22 likes in 84 posts.
Hope this document will tranquilize visitors/users !
Jean.
If that's what you think.
#22 Posted: 2019/12/11 19:05:16
Does it work for you ... SS 7251 users please confirm ?
#23 Posted: 2019/12/11 21:25:41
CBG
CBG
78 likes in 312 posts.
Hello Jean
Yes, It works
Carlos
#24 Posted: 2019/12/12 00:09:00
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Originally Posted by: MarB [url=/forum/yaf_postsm60156_Program-for-Linear-and-Polynomial-Fit.aspx#post60156][/url]If that's what you think.
It works. Thank you MarB.
#25 Posted: 2019/12/12 07:41:20
NDTM Amarasekera
NDTM Amarasekera
That's my solution
- to separate the functions from matrix building,
- to use vectorize for speed
Apparently, the function f(#x):=1 if n=0 has a problem?. Or is it redundant?
For values n>0, the "otherwise" condition yields correct results irrespective of values in "if" condition.
Please check.
#26 Posted: 2019/12/12 07:53:51
Martin_B
Martin_B
just put the 1 into a 1x1 matrix. That's all.
(And if you want to use units with the X Vector, just remove the eval and evaluate symbolically.)
That's my solution
Please check.
#27 Posted: 2019/12/12 10:21:08
NDTM Amarasekera
NDTM Amarasekera
Hi
Still the same error when n=0.
Better if you can post the SM file please.
#28 Posted: 2019/12/12 11:21:42
Martin_B
Martin_B
Sorry, I didn't realize, that vectorize behaves unexpectedly (to me), when the function does not include 'x'.
So I changed f to f(x):=[1+0*x] and now it works. The file is attached.
PolyFit.sm (11.92 KiB) downloaded 1086 time(s).
I would expect the results of g and h to be the same, and to be a 3 items long vector.
sergio 2019/12/12 16:13:00
#29 Posted: 2019/12/12 11:49:54
NDTM Amarasekera
NDTM Amarasekera
Hi
Now I get same results as yours.
But the result (19.0833) of the Polyfit() function when n=0 ----> Does it have any meaning?
I have no idea. I was only testing it for all possible conditions..
Cheers MarB.
Note: Incidentally, 19.0833 happens to be the Mean of Y vector.
#30 Posted: 2019/12/12 13:06:39
IMHO ... no need to complicate matters.
Modular design is easier to fix.
More automated is OK if you intend to poly for the entire Planet.
PolyFit (2).sm (46.79 KiB) downloaded 1102 time(s).
#31 Posted: 2019/12/12 15:12:19
1,123 likes in 1,795 posts.
Hi. This is in case you want to interpolate with an horizontal line.
PolyFit.sm (159.33 KiB) downloaded 1120 time(s).
PolyFit.pdf (748.27 KiB) downloaded 664 time(s).
sergio 2019/12/12 16:12:00
#32 Posted: 2019/12/12 15:15:52
NDTM Amarasekera
NDTM Amarasekera
Thank you, Alvaro.
