Program for Linear and Polynomial Fit
Program for Linear and Polynomial Fit - Сообщения
#21 Опубликовано: 11.12.2019 13:31:21
Martin_B
Martin_B
22 сообщений из 84 понравились пользователям.
Hope this document will tranquilize visitors/users !
Jean.
If that's what you think.
#22 Опубликовано: 11.12.2019 19:05:16
Does it work for you ... SS 7251 users please confirm ?
#23 Опубликовано: 11.12.2019 21:25:41
CBG
CBG
Hello Jean
Yes, It works
Carlos
#24 Опубликовано: 12.12.2019 00:09:00
NDTM Amarasekera
NDTM Amarasekera
Originally Posted by: MarB [url=/forum/yaf_postsm60156_Program-for-Linear-and-Polynomial-Fit.aspx#post60156][/url]If that's what you think.
It works. Thank you MarB.
#25 Опубликовано: 12.12.2019 07:41:20
NDTM Amarasekera
NDTM Amarasekera
That's my solution
- to separate the functions from matrix building,
- to use vectorize for speed
Apparently, the function f(#x):=1 if n=0 has a problem?. Or is it redundant?
For values n>0, the "otherwise" condition yields correct results irrespective of values in "if" condition.
Please check.
#26 Опубликовано: 12.12.2019 07:53:51
Martin_B
Martin_B
just put the 1 into a 1x1 matrix. That's all.
(And if you want to use units with the X Vector, just remove the eval and evaluate symbolically.)
That's my solution
Please check.
#27 Опубликовано: 12.12.2019 10:21:08
NDTM Amarasekera
NDTM Amarasekera
Hi
Still the same error when n=0.
Better if you can post the SM file please.
#28 Опубликовано: 12.12.2019 11:21:42
Martin_B
Martin_B
Sorry, I didn't realize, that vectorize behaves unexpectedly (to me), when the function does not include 'x'.
So I changed f to f(x):=[1+0*x] and now it works. The file is attached.
PolyFit.sm (11,92 КиБ) скачан 1267 раз(а).
I would expect the results of g and h to be the same, and to be a 3 items long vector.
sergio 12.12.2019 16:13:00
#29 Опубликовано: 12.12.2019 11:49:54
NDTM Amarasekera
NDTM Amarasekera
Hi
Now I get same results as yours.
But the result (19.0833) of the Polyfit() function when n=0 ----> Does it have any meaning?
I have no idea. I was only testing it for all possible conditions..
Cheers MarB.
Note: Incidentally, 19.0833 happens to be the Mean of Y vector.
#30 Опубликовано: 12.12.2019 13:06:39
IMHO ... no need to complicate matters.
Modular design is easier to fix.
More automated is OK if you intend to poly for the entire Planet.
PolyFit (2).sm (46,79 КиБ) скачан 1291 раз(а).
#31 Опубликовано: 12.12.2019 15:12:19
Hi. This is in case you want to interpolate with an horizontal line.
PolyFit.sm (159,33 КиБ) скачан 1312 раз(а).
PolyFit.pdf (748,27 КиБ) скачан 813 раз(а).
sergio 12.12.2019 16:12:00
#32 Опубликовано: 12.12.2019 15:15:52
NDTM Amarasekera
NDTM Amarasekera
Thank you, Alvaro.
