Help needed in solving this equation...
Help needed in solving this equation... - This equation has variables on both right and left side of the equation...struggling to solve - Сообщения
#1 Опубликовано: 25.11.2012 17:22:31
paula1980
paula1980
Hello
I have spent hours on solving the below equation on MathCad or Excel....however got nowhere
Can anyone please able to help me?
As you can see in the equation below, I have to plot the value of hc but its located on both right and left side of the equation. All other variable (ao, f and v etc.) are constants.
An Equation
Please help if you can.
Thank you
#2 Опубликовано: 25.11.2012 19:32:28
1 435 сообщений из 2 913 понравились пользователям.
The equation it's not visible, could you attach a SMath file to the post?
However you can use the solve function (here there is an example for an implicit equation)
regards,
w3b5urf3r
#3 Опубликовано: 25.11.2012 20:04:31
paula1980
paula1980
Many thanks for your response.
I have never used SMath but will try attaching the Excel file for your reference.
Thanks however for mention about this Solve equation...I will have a look at this.
P-Calculation.xls (98,5 КиБ) скачан 533 раз(а).
#4 Опубликовано: 25.11.2012 21:13:02
You're welcome
I attach here the SMath solution for your question.
best regards,
w3b5urf3r
#5 Опубликовано: 26.11.2012 10:12:25
paula1980
paula1980
Excellent, thanks w3b5urf3r! That answer is close to what I was looking for!
This program looks very simple to use.
One more question
: In the above example, I assumed that hc is not a function of any other additional variable. What if, in the same equation, variable f is a function of x (like f=2x, where x range from 0 to 1 (0, 0.1, 0.2, 0.3..1). Can we then plot hc as a function of x on a graph using SMath?
Thank you for your help and please only suggest answer to my question if it does not take too much of your time. I truly appreciate your help and time.
#6 Опубликовано: 26.11.2012 13:20:40
One more question
You can do it in different ways; in the attached example I define a vector of x values (using the range() function) and then I've solved an equation for each x value with a loop and then I create the matrix to plot. Obviously if you know very well the output behavior you can do all the operations "on the fly", inside the loop.
regards,
w3b5urf3r
#7 Опубликовано: 27.11.2012 20:20:32
paula1980
paula1980
Thanks w3b5urf3r! This is terrific.
I have spent a few hours on SMath and it looks very user-friendly. It has similar feeling of using Mathcad but much faster with some differences.
