page break in pdf dependent on document layout
page break in pdf dependent on document layout - Сообщения
#1 Опубликовано: 22.09.2021 06:51:05
SamB
SamB
Hello everyone,
I am a structural engineer and use SMath a lot for my job.
I create my calculations and then save them as pdf files to import them into my overall document (well actually it does all that automatically). Whether the "save as" or "print" function is used doesn't seem to matter.
And I noticed some very odd behaviour. I think it is a bug, but am not sure.
Here's the thing:
If I add text near the bottom of a page, the pdf document will be saved with an empty page (or not) depending on the document layout settings (bottom right corner, not the page layout). If set to "Pages view" no extra page will be created. If set to "Printing bounds" it will create an extra page, that is completely empty. The position of the text on the page (either as viewed in SMath or the pdf file) does not change. Problem is that I really dislike pages view for multipage calculations (and I often need the margins).
I use SMath build 0.99.7822 and hate to produce lots of empty pages.
Actually I have been aware of this for some time and tried to compress my calculations so that I do not use the last lines on the last page, but just decided, that is no solution.
Any suggestions?
Thanks, Sam
#2 Опубликовано: 22.09.2021 11:04:58
Any suggestions?
Experiment your document with and w/o header/footer.
That will guide you how many empty lines up/down page breaks
to produce perfect *.PDF
#3 Опубликовано: 22.09.2021 13:35:43
... from some times ago.
Geoff Auckland.pdf (105,39 КиБ) скачан 815 раз(а).
#4 Опубликовано: 23.09.2021 03:11:24
SamB
SamB
Hello Jean,
thank you for your suggestion. Since I expected it to be about header/footer (and margins), I actually tried that beforehand (but forgot to tell).
But my issue is more diffcult than that. How I view the document whilst editing influences the publishing of an empty page in a pdf document. As far as I have found, nothing else.
Thanks, Sam
#5 Опубликовано: 23.09.2021 11:13:57
Hello Sam,
If not confidential, attach the document.
Collabs that have "Save as PDF" Smath versions
may be able to doctor, specify your SS version.
My SS 6179, print virtual CutePDF.
Adobe Reader open 1/1 original Smath document.
#6 Опубликовано: 24.09.2021 03:17:55
SamB
SamB
Файл не найден.Файл не найден.Файл не найден.
Hello Jean,
I did attach. There is nothing confidential it is just "asd" at the bottom of the page :-).
I attached the smath file and both pdf files.
I actually don't understand, what you mean by SS Version? SMath? 0.99 build 7822.
I did try both "save as" and print via pdfcreator. Both turned out the same way. But thank you I just noticed it is doing it in print preview as well. So it seems to just be SMath, I think.
Can anyone reproduce?
Thanks, Sam.
#7 Опубликовано: 24.09.2021 09:53:09
You may be right wrt SS [SmathStudio] that have PDF option.
On my SS 6179, print preview is by page.
Often web PDF have blank pages in between populated pages.
Damned annoying ... from recollection: late NIST
Just save PdfCreator as 'page view' to eliminate blank pages.
#8 Опубликовано: 24.09.2021 14:49:06
Same odd behavior with "save as pdf" under Linux using your sample file.
If document layout is set to "Printing Bounds" or "No bounds", a blank page is created.
When layout is set to Pages view, no blank page. Pdf is as it should be.
#9 Опубликовано: 28.09.2021 05:53:53
SamB
SamB
Hello Jean, hello Overlord,
thank you for your replies. Although I must admit, I do not gain much from them.
Overlord seems to be able to replicate the problem - but does not seem to be able to pinpoint the issue.
And Jean seems to have an older version of SS and it seems to function correctly.
So, is it a bug? I think so. It is very odd behaviour, that the amount of pages produced is dependent on how I view a document. Is there a solution? So far, it doesn't seem so.
Overlord, if you create a new file, does it happen too?
So any help?
Thanks Sam
#10 Опубликовано: 28.09.2021 08:26:56
1. Visit late Samples,
2. Select one of those Smath documents,
3. Try to PDF up until you find the trick
not to interlace blank pages.
Maybe some Collab will do it.
#11 Опубликовано: 28.09.2021 13:52:22
Yes, doesn't matter if I create a new file and wrote to last available area.
Probably bottom of region boundaries overflow the current page and cause the additional blank page.
Or length for bottom of page in page setup does not taken into account correctly. This is a bug indeed.
#12 Опубликовано: 28.09.2021 20:41:33
If the bug is wrt some Smath save as *.PDF ....
that is is a bug not reported. It takes two /three
weeks to test new version of per say 3000 documents.
Help yourself step by step:
1. download Symbolic COMPENDIUM Appendix.
2. accept created SS 6179
3. open/run
4. select the two first pages between separators
5. copy/paste in your actual Smath version
6. print as virtual your PDF Creator
7. save as ... read back Adobe reader
If you have blank pages, download/install CutePDF
repeat [6, 7]
PDF creator(ssssssss) are WYSISWYG.
What they see is what they create.
My CutePDF is same in Smath that I used Mathcad 20 years ago.
#13 Опубликовано: 29.09.2021 02:12:13
SamB
SamB
Hello Jean,
thank you for the suggestion! I tried a clean install on another pc (latest version), same result.
However, if I download examples and open them, it depends on who posted them. Your's all work correctly, some others work too. I found at least one with the same behaviour I described. And I also found one with an even stranger behaviour - the position of the text on the page in page preview changed, depending on view layout. SO I think there is definitely something off with view layout and export.
Sam
#14 Опубликовано: 29.09.2021 08:23:31
My dear friend,
At this point, doctoring is for Designers.
I have recollection for save as PDF feature request,
once implemented nobody reported problem.
Hope for better news ... Jean.
