Export to Tab Delimited Text file
Export to Tab Delimited Text file - Сообщения
#1 Опубликовано: 31.08.2016 22:28:37
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
Is there a direct way to export a matrix to a tab delimited text file??
I have been exporting it to excel, then saving as a tab delimited text file. I'm hoping I could skip this extra step.
#2 Опубликовано: 01.09.2016 02:26:59
Mike Kaganski
Mike Kaganski
http://en.smath.info/forum/yaf_postst1642_Data-Exchange-plugin.aspx
С уважением, Михаил Каганский
#3 Опубликовано: 01.09.2016 13:32:32
Ernesto
Ernesto
Thanks Mike for pointing me to the other thread. I looked over the 8 pages of the thread, but no where does it say anything about tab delimited values, only comma delimited values.
#4 Опубликовано: 01.09.2016 13:54:56
I might try to add an optional argument to setup a custom separator
As alternative you can build your own functions using fwrite() from DataExchange + var2str(...) from CustomFunctions
example attached: export2tsv.sm (6,07 КиБ) скачан 1282 раз(а).
Ernesto 01.09.2016 19:33:00
#5 Опубликовано: 01.09.2016 18:39:17
Mike Kaganski
Mike Kaganski
Sorry for not being clear.
There's no such standard as "tab delimited values file", only CSV, but the CSV allows for different kind of separators.
As Davide says, it requires a developer to add that ability, and I suppose, that would be great.
#6 Опубликовано: 01.09.2016 19:33:10
Ernesto
Ernesto
Thanks for the file Davide, worked perfectly!
