Vectorize Issue: How to Get 2D Matrix Output?
Vectorize Issue: How to Get 2D Matrix Output? - Сообщения
#41 Опубликовано: 22.04.2022 16:12:10
Download Kirby NIST data set ... fit.
I will correct your defective design.
Just that one for learning step.
#42 Опубликовано: 22.04.2022 16:25:13
Yeah, you should learn there is no such thing as kW/hr.
Unit of power is kW, it is written as kilowatt. No time involved.
And poise is the unit of dynamic viscosity. (Pa*s) or (kg/m*s)
In pump calculation you should use stokes. (m^2/s)
#43 Опубликовано: 22.04.2022 16:51:42
Mark R Harris
Mark R Harris
5 сообщений из 90 понравились пользователям.
It would have been a really fast learning step if SMath's units were used from the outset.
Time for an apology and a retraction (SI units being unsuitable for process control) Jean, me thinks.
This has not been pleasant to watch.
#44 Опубликовано: 23.04.2022 19:53:59
Yes Mark, adapt project system/standards,
accordingly to the Control Engineer Tool Box ... standards
Nothing dogmatic/Bible.
Mark R Harris 23.04.2022 20:01:00
#45 Опубликовано: 23.04.2022 20:05:34
Mark R Harris
Mark R Harris
Excellent, thanks Jean.
It may be worth doing some weeding to remove examples that may lead noobies astray.
