More vector-producing vector results
More vector-producing vector results - mfos - Сообщения
#1 Опубликовано: 20.10.2013 16:19:55
mfos
mfos
This is a little similar to my last post, but different enough to warrant its own post. However, it might help to solve both.
The easiest way to put this, is that I am getting 2 - 4 sized vectors for reasonably complicated equations. However, on major simplification, I have whittled one down to the following:
#2 Опубликовано: 20.10.2013 16:43:28
1 350 сообщений из 2 262 понравились пользователям.
Can you attach a screenshot of your settings under Tools> Options> calculations or the relevant settings from your settings file (as found in SettingsDirectory())? And perhaps include any of the mentioned equations?
#3 Опубликовано: 20.10.2013 16:51:45
mfos
mfos
This was solved in the previous post ("Square Root Result" ). Turns out it was the same issue.
Thanks anyhow!
