Beta: SMath Studio 0.99.7691 (21 January 2021) - Сообщения
Изменения, входящие в версию 0.99.7691
Улучшения
- Automatic replacement context menu item added to TextRegion;
- Search in TextRegion significantly improved;
- Text Region: Show all characters context menu item added.
Исправления
- Visible special XML symbols fixed in Text Region;
- Issues related to work with ordered/unordered lists fixed.
Разное
- Refactoring.
Скачать
SMathStudioDesktop.0_99_7691.Mono.tar.gz (1,41 МиБ) скачан 2859 раз(а).
SMathStudioDesktop.0_99_7691.Setup.msi (2,28 МиБ) скачан 8181 раз(а).
WroteProblem with areas. The titles disappeared
Same problem with my SM files too.
WroteWroteProblem with areas. The titles disappeared
They are there, but not visible unless you try to select the titles.
It is same with smath book with quite sometime, maybe related to document mode, it started with build 7666.
Even if you have disabled or never activated it area titles disappeared from me since document mode is released.
It will be fixed soon I guess.
Regards.
WroteIt will be fixed soon I guess.
True.
