Translation creating
Translation creating - Сообщения
#1 Опубликовано: 28.04.2009 00:27:23
2 345 сообщений из 4 059 понравились пользователям.
Группа: Super Administrator
If you want and can help to the SMath Project by creating a translation for SMath Studio, please, follow the steps below:
  1. Notify developers about it by sending an e-mail on support@smath.info;
  2. Receive file(s) for translation(s) from developers (it will be txt file of one of the supported language, usually it's English file, if you want another one, please tell this in e-mail on step 1);
  3. Change received files text-content with yours (recommended) or create a new one. In any case you should save all special chars represented in source file(s);
  4. Save modified file(s) as shown on screenshots below (the most important thing is that you should use UTF-8 encoding) and then send it back to developers.
Figure 1: Modified file opened with Windows Notepad.
Figure 2: Press "File" on Toolbar and then "Save as..".
Figure 3: Choose directory where you want to save file.
Figure 4: Specify "File name" and UTF-8 (sic!) "Encoding".
Figure 5: Press "Save" button to finally save the file.
We are allways appreciate you help. Thanks in advance.
