Animation of mechanisms - Ber7 - Сообщения
Drilling a square hole (Cross section of the drill is Reuleaux triangle)
Reuleaux triangle is rotated around its center of gravity, and the center of gravity
moves around the center openings.
https://smath.com/wiki/GetFile.aspx?File=Reuleauxtriangle.rar
Drilling accurate (without rounding) square hole
The disc in the form of a modified Reuleaux triangle
moves inside a square frame . A drill (green dot in the center
of the yellow circle) makes an exact square hole.
References:
Wagon S. Mathematica in Action: Problem Solving .
Through Visualization and Computation,Springer, 2010
https://smath.com/wiki/GetFile.aspx?File=Drilling2.rar
References:
Square-Hole Drill (continued)
Using the coupling Oldham to convert the rotational motion
of the drive shaft to move the tool to the square trajectory.
https://smath.com/wiki/GetFile.aspx?File=SquareHole.rar
Drill, coupled with the Reuleaux triangle
Chassis for Mars Curiosity Rover
Soft landing "Curiosity" on the surface of Mars was held August 6, 2012
https://smath.com/wiki/GetFile.aspx?File=Curiosity.rar
Rocker-bogie mechanism that can navigate the stairs.C.M.-center of mass.
1.All three wheels are actuated independently.
Climbimg1.rar (4,15 КиБ) скачан 617 раз(а).
2. All three wheels are passive and the part of the rocker-bogie mechanism body is pulled
up by the external force as in the case of shopping carts.
Climbing2.rar (4,17 КиБ) скачан 578 раз(а).
Animation kinematic characteristics
Above: The trajectory of the point B, the vectors of its velocity and acceleration;
Below: the dependence of the velocity and acceleration of point B on
crank angle β (t)
kinchar1.sm (37,74 КиБ) скачан 1494 раз(а).
kinchar.smz (11,6 КиБ) скачан 1741 раз(а).
crank angle β (t)
Impressive stuff Ber.
Hi,Ber7
All your post for moving parts are very, very, very...., goods, fantastics.!
Fridel Selitsky 29.09.2013 10:23:00
Animation spatial mechanisms
To calculate the position of the mechanism will use
techniques developed A.B.Ivanov.His work on 3d
animation mechanisms made in Mapl, publishes A.B.Ivanov
online
http://forum.exponenta.ru/viewtopic.php?t=12842
Of the examples from this site I suffered in a programming environment SMath Studio
1. Sarrus linkage 1
Sur111.smz (8,13 КиБ) скачан 1715 раз(а).
online
1. Sarrus linkage 1
Davide Carpi 21.01.2014 18:08:00
Nice job ber, as usual
BTW I can't download the first animation (Sarrus linkage 1)
Best regards,
Davide
Best regards,
Davide
Thank you,Davide,now you can download the file.
