Analog Clock
Analog Clock - A simple animation - Сообщения
#1 Опубликовано: 09.07.2013 10:24:35
A simple animation
Best Regards,
Davide
AnalogClock_viewer.7z (355,86 КиБ) скачан 814 раз(а).
ioan92 09.07.2013 11:21:00, Вячеслав Мезенцев 11.07.2013 13:12:00, Andrey Ivashov 10.07.2013 08:27:00, Fridel Selitsky 09.07.2013 14:27:00
#2 Опубликовано: 09.07.2013 16:51:49
Fridel Selitsky
Fridel Selitsky
Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s).
Best Regards,Ber7.
AnalogClock1.sm (22,29 КиБ) скачан 1396 раз(а).
Davide Carpi 09.07.2013 17:15:00, Andrey Ivashov 10.07.2013 08:27:00
#3 Опубликовано: 09.07.2013 17:20:04
Thank you ber,
this make the script faster and easier to read
Best regards,
Davide
P.S. worksheet updated
#4 Опубликовано: 11.07.2013 05:37:01
Fridel Selitsky
Fridel Selitsky
Davide,if your program to change the settings a bit, we get
"real" analog clock (all the arrows are moving continuously).
Best Regards,
Ber7
AnalogClock2.sm (21,44 КиБ) скачан 1457 раз(а).
Вячеслав Мезенцев 11.07.2013 13:12:00, Davide Carpi 11.07.2013 08:45:00
#5 Опубликовано: 11.07.2013 08:49:18
I see, wonderful
#6 Опубликовано: 16.07.2019 00:08:53
Best Regards,Ber7.
Glorious old vintage, before I joined Smath.
More elegant needles in there ... needs be animated
attach]31143[/attach]
#7 Опубликовано: 18.07.2019 14:24:18
Oscar Campo
Oscar Campo
Cheers to all!
This is my 5 cents to this thread. I only took some pieces of code from here and there, a little bit of make up, and.. voilá: my version of analog clock that works on "real" time
Updated 19jul2019 (Special thanks to [USERLINK]Razonar[/USERLINK]):
Annoying "purple line" eliminated. Path for sound files fixed. More realistic movement of hands clock.
MyClock2.sm (38,86 КиБ) скачан 1340 раз(а).
click_low.wav (171,1 КиБ) скачан 354 раз(а).
alarm.wav (891,03 КиБ) скачан 361 раз(а).
frapuano 18.07.2019 14:53:00, Alvaro 19.07.2019 02:04:00
#8 Опубликовано: 19.07.2019 02:25:06
Hola Oscar. Very nice effects.
You can improve it multiply Play() by 1000 or something else but big. This avoid the horizontal purple line in the clock.
Also you define the location of the files as "D:\sound.wav". Using 1000*Play("sound.wav" ) searches sound in the same directory of the SMath file.
Finally notice that your blue hours hand jumps between hours, but not follow the actual movement of an hours hand clock. You need to take 1/2-1/6*el(NOW,1)-el(NOW,2)/600 as the arguments for sin, cos functions for place it between exact hours considering the minutes too.
frapuano 19.07.2019 05:23:00, Oscar Campo 19.07.2019 17:39:00
#9 Опубликовано: 19.07.2019 18:15:08
Oscar Campo
Oscar Campo
Thanks for your suggestions Also I considering the seconds in the movement of the minutes hand for a more realistic appearance.
I've updated the file and I uploaded the new one, you can check it here.
