Beta: SMath Studio 0.99.7251 (08 November 2019)
Beta: SMath Studio 0.99.7251 (08 November 2019) - Сообщения
#21 Опубликовано: 01.04.2020 08:50:17
1 554 сообщений из 1 864 понравились пользователям.
Hello dear Smath fans,
with v0.99.7251 I cannot open any longer the "Format..."
menu with the right mouse button on inserted x-y-Plots.
After clicking on it, Smath is freezed.
After minimizing Smath to the task bar with third party tools
and reopen this Smath process again from the task bar
I am able to edit the open document without issues.
But as soon as I try to use "Format..." again on any x-y-plot,
the freezing happens againg. So the usual format pop-up
window does not appear at all.
Is this the right forum group for this issue?
Or is it better to place it elsewhere? E. g.
"SMath Studio Forum » SMath Studio » Bugs & Problems"
Thanks and regards
In this case try to press [Alt]+[Space] for context menu and move hidden Format window. The component saves the coordinates and position of the settings window. When restoring a window, it may happen that the coordinates are outside the current desktop.
sergio 01.04.2020 11:36:00
#22 Опубликовано: 01.04.2020 11:54:46
Mathys
Mathys
Thank you Viacheslav,
good to remember this for future occuring of this effect.
Meanwhile it disappeared, because I re-installed the plugins.
However it might be necessary to use:
  • not only "Alt-Space" but also
  • "Cursor down" and
  • "Enter" and
  • "Cursor left/right/up/down2
to catch and move this lost format windows back to the visible screen.
There are also special third party "Window Hunter" tools,
but I am not aware if they can hunt only windows applications
or also all kind of pop-up-windows from these applications.
Thank you and best Regards
Rudolf
#23 Опубликовано: 05.06.2020 05:01:05
Jacques CHEN
Jacques CHEN
0 сообщений из 11 понравились пользователям.
is there something wrong, i cant install any plugin. when i install plugin the smath will close by itself
#24 Опубликовано: 05.06.2020 12:36:11
Try this:
  1. Open a file explorer window and in the address bar type %APPDATA% and hit enter
  2. Find the SMath folder and rename it (f.e. SMath_old)
  3. Launch SMath Studio and check if the problem is solved
#25 Опубликовано: 07.06.2020 01:30:00
Jacques CHEN
Jacques CHEN
Try this:
I tried it, but it didn't work. I opened %APPDATA% again,like this picture. I think is some problem about uuid.
#26 Опубликовано: 01.08.2020 16:15:12
1 355 сообщений из 2 270 понравились пользователям.
The interactive "Getting started" guide has been updated.
Many thanks for feedback and contributions by Ihor Rokach (Holy Cross Technical University in Kielce, Poland).
Changes:
- Polish translation
- Minor corrections (typos)
- Improved consistency of keyboard input instructions
- Revised section on substitution function at(), now independent of Maxima (which users might not have installed)
- some images now are language-specific (using text regions with embedded images)
The version is marked as "beta" because it requires SMath Studio build 7251. You need to install some plug-ins.
sergio 01.08.2020 16:20:00, Davide Carpi 01.08.2020 16:33:00, IVR 02.08.2020 15:52:00, Alvaro 04.08.2020 06:33:00
