How to expand a function into Taylor series?
How to expand a function into Taylor series? - Сообщения
#1 Опубликовано: 09.01.2021 10:48:23
netsonicyxf
netsonicyxf
2 сообщений из 79 понравились пользователям.
I can do in mathcad Prime
How to do it in SMath Studio?
#2 Опубликовано: 09.01.2021 10:54:22
I see no interest, why ?
cos(x) is coded in Windows on Padé normalized rational fraction,
lot more stable and free of Taylor obsolete expansion.
If you insist, will check your curiosity.
#3 Опубликовано: 09.01.2021 11:18:30
netsonicyxf
netsonicyxf
I just want to know how in the Smath, and cos(x) is just a simple example, it doen't necessarily mean I will use Taylor series for cos(x).
I found Taylor, but I don't know why it doesn't work.
#4 Опубликовано: 09.01.2021 12:00:35
simply not cracked in Smath ... from what I tried.
#5 Опубликовано: 09.01.2021 12:10:52
Hi. First, because "Taylor" isn't the maple command, it is "taylor", in lowercase. Second, because maple returns the answer with an "O" notation. You can use convert/polynom to get a result that SMath can handle.
SMath' maple plugin use version 6; here you can find two maple manuals, but for maple 7: https://www.maplesoft.com/documentation_center/history.aspx
#6 Опубликовано: 09.01.2021 13:16:47
... cracked otherwise, ignoring Taylor.
#7 Опубликовано: 09.01.2021 14:10:47
... few more that may be useful.
Symbolic Convert Parfrac Primary FNCTS.sm (118,96 КиБ) скачан 1328 раз(а).
