Automation of Plot Input
Automation of Plot Input - Automation of Plot Input - Сообщения
#1 Опубликовано: 30.07.2016 14:05:56
Ernesto
Ernesto
13 сообщений из 74 понравились пользователям.
I would like to be able to automate the creation of the system of equations for a plot.
For the example attached, the function b(c,x) is used to plot, with the matrix "a" as the input. Currently with this setup, I would have to input each row of the function individually into the system of equations for a plot.
I would like to be able to increase or decrease the size of matrix "a" without having to edit the input of the plot.
Any ideas on how I could do that???
plots.sm (3,79 КиБ) скачан 1262 раз(а).
#2 Опубликовано: 30.07.2016 17:02:33
Fridel Selitsky
Fridel Selitsky
Try so
plots1.sm (3,95 КиБ) скачан 1272 раз(а).
Ernesto 30.07.2016 17:53:00, Davide Carpi 30.07.2016 19:20:00
#3 Опубликовано: 30.07.2016 17:55:27
Ernesto
Ernesto
That's great! For the application that I needed, it as a system of matrices instead of a system of equations, and for that case I used mat2sys1.
Thanks for the help, I have never used that function, so I don't think I would've come up with using it.
#4 Опубликовано: 31.07.2016 10:25:46
also the converse sys2mat(,)
also: sys2mat(|(mat2sys(Vifft)|)
also: sys2mat(fft(Y))
#5 Опубликовано: 31.07.2016 10:33:49
Ernesto,
That's what I meant in "also +++"
Fourier Geometric Coplanar COMPLEX.sm (17,47 КиБ) скачан 1238 раз(а).
