It's possible to block the negative input in field's?
It's possible to block the negative input in field's? - Сообщения
#1 Опубликовано: 12.09.2022 15:33:22
Hildebrando Pereira dos Santos Junior
2 сообщений из 21 понравились пользователям.
Hey Guys,
It's possible to block the negative input in field's using smath viewer?
#2 Опубликовано: 14.09.2022 09:40:10
Nope, the best way to accomplish it easily is to filter the output applying abs() to the value before using it.
a:1
a:abs(a)
f(a): ...
#3 Опубликовано: 14.09.2022 09:47:52
Thanks Davide! Actually i do this, i will use an formatted label to show some message warning the user
#4 Опубликовано: 14.09.2022 10:51:57
You are welcome. As alternative one can develop a region that translates into a TextBox control with mask/validation filters. It might be tricky depending on the filter but it is feasible.
#5 Опубликовано: 14.09.2022 11:04:57
Wow! It will be a great plugin! It can be extend the use of smath viewer in so many ways
#6 Опубликовано: 14.09.2022 15:53:11
It's possible to block the negative input in field's using smath viewer ?
Pretty simple to zap negative values:
1. transform negatives to '0'
2. strip vector from '0'
No need using Smath Viewer.
Random [rnd(n)] Filter.sm (10,03 КиБ) скачан 1037 раз(а).
Composite clean negatives.
Thanks Jean, but it's not the case.
I have an long application developed in Smath Studio using Smath Viewer, and some of my algorithms need's a positive input for bending moment's. For now showing a warning message, and using an absolute value work, it's not the more elegant solution, but work.
#7 Опубликовано: 14.09.2022 16:41:46
I have an long application developed in Smath Studio ... , and some of my algorithms need a positive input for bending moment's.
The very original document at the algorithms level might help.
Not my discipline, but curious.
Refreshed version of the previous Filter Negatives.
Jean.
Random [rnd(n)] Filter.sm (10,07 КиБ) скачан 1030 раз(а).
Sure! The document is here:
DIMIS_219.sm (838,58 КиБ) скачан 1251 раз(а).
The section is called "Flexão Composta" the value of Msd, for this algorithm need's to be positive.
#8 Опубликовано: 14.09.2022 16:44:08
Get use to what he do, but never bow down or surrender.
He will try to hijack your topics with totally unrelated replies.
Just report his irrelevant posts, mods will take care it eventually.
