corrupted file
corrupted file - Ioan - Сообщения
#1 Опубликовано: 03.07.2012 01:00:15
Ioan
Ioan
1 сообщений из 26 понравились пользователям.
Hi all,
Trying to reopen a file that I wrote and that refused to be closed normaly, I receive this message:
"Unexpected end of file occured.
The following elements are not closed:
result, math, region, regions. Line 82490, position 12."
I posted the file here:
file
Is it possible to recover the file ? If yes, how ?
Thanks a lot for any help,
Ioan
NMyMz.zip (454,08 КиБ) скачан 482 раз(а).
#2 Опубликовано: 03.07.2012 02:53:34
kmihaylovich
kmihaylovich
8 сообщений из 131 понравились пользователям.
Please attach your file to the forum: http://en.smath.info/forum/yaf_help_index.aspx?faq=attachments
#3 Опубликовано: 03.07.2012 02:56:52
the link to the file points to a hoster which requires login/registration. I won't create a login at a filehoster just to download a single file. You might use dropbox or the smath wiki file management.
The problem might be solved by just closing the xml tags in the file, but I can't try...
If that is the solution than I guess that SMath should be able to propose this approach and apply the fix.
Best regards, Martin
#4 Опубликовано: 03.07.2012 03:14:56
Please attach your file to the forum: http://en.smath.info/for...dex.aspx?faq=attachments
I agree, Ioan please attach the file directly to the forum or use a registration-free hosting service...
The solution is indicated by mkraska and the result is in the attached file
regards,
w3b5urf3r
#5 Опубликовано: 03.07.2012 03:27:58
Ioan
Ioan
Thanks for your answers,
Many thanks to w3b5urf3r for the recovered file.
Now the original file is attached to my first post.
I still have a problem with this file:
all results are in fractional mode, against my temptatives of changing.
#6 Опубликовано: 03.07.2012 07:18:06
You are welcome
simply change the result optimization from "none" to "numeric"
regards,
w3b5urf3r
#7 Опубликовано: 03.07.2012 07:28:43
Ioan
Ioan
Thanks again w3b5urf3r.
Best regards to all,
Ioan
#8 Опубликовано: 07.09.2012 09:13:34
Anonymous
Anonymous
Hello there,
I have similar problem with my document. I saved file on hard disk but when i reopened it all text below pagebreak stamp disappeared.
Please look at it, help if possible it is important for me.
File with lost data.sm (483,59 КиБ) скачан 1435 раз(а).
#9 Опубликовано: 09.09.2012 12:09:04
Edward Ulle
Edward Ulle
21 сообщений из 182 понравились пользователям.
I don't find anything wrong with your file. It opens fine on my computer with Win 7 and SMath 0.95. You have collapable areas within a collapsable area.
Ed
#10 Опубликовано: 18.09.2012 03:40:08
Anonymous
Anonymous
Hi there,
I have one more corrupt file. This time I can not even open it.
Thanks for every help.
ZELBET_Przebicie_PNB_03264_2002_v1.sm (497,75 КиБ) скачан 1495 раз(а).
#11 Опубликовано: 18.09.2012 04:19:53
Hi there,
Hi Anonymous,
The recovered file is in the attachments.
@Andrey The issue is in these lines, at the end of the Anonymous original file...
    <region id="163" left="0" top="7227" width="326" height="334" color="#000000" bgColor="#ffffff" fontSize="10">
    <math error="9">
      <input>
        <e type="operand">Typ</e>
        <e type="operand" style="string">1</e>
        <e type="operator" args="2">≡</e>
        <e type="operand">A</e>
        <e type="operand">b</e>
        <e type="operand">2</e>
        <e type="operand">d</e>
        <e type="operator" args="2">*</e>
        <e type="operator" args="2">+</e>
        <e type="bracket">(</e>
        <e type="operand">1</e>
        <e type="operator" args="2">:</e>
        <e type="operand">A.2</e>
        <e type="operand" style="string">Nie dotyczy</e>
        <e type="function" preserve="true" args="4">line</e>
        <e type="operand" style="string">2</e>
        <e type="operand" style="string">3</e>
        <e type="operator" args="2">|</e>
        <e type="operand">B</e>
        <e type="operator" args="2">-</e>
        <e type="operand">H</e>
        <e type="operand">h</e>
        <e type="operator" args="2">&lt;</e>
        <e type="operand">L</e>
        <e type="operand">l</e>
        <e type="operator" args="2">&amp;</e>
        <e type="operand">d.1</e>
        <e type="operator" args="2">≥</e>
        <e type="operand">d.2</e>
        <e type="operand">#</e>
        <e type="function" preserve="true" args="5">line</e>
        <e type="function" preserve="true" args="2">if</e>
        <e type="function" preserve="true" args="4">if</e>
        <e type="function" preserve="true" args="3">if</e>
      </input>
    </math>
  </region>
regards,
w3b5urf3r
ZELBET_Przebicie_PNB_03264_2002_v1.sm (492,56 КиБ) скачан 1492 раз(а).
#12 Опубликовано: 21.09.2012 07:45:29
Anonymous
Anonymous
Thanks for help w3b5urf3r. It is working now.
#13 Опубликовано: 27.12.2013 20:02:04
Ann163
Ann163
Unfortunately I have a similar problem with my file.
After I finished my document it didn't saved somehow and now when I'm trying to open it I just see a grey background
I would be really grateful if someone could help me with it, because it's very important for me.
Best regards,
Ann
Słupy.sm (2,61 МиБ) скачан 16 раз(а).
#14 Опубликовано: 27.12.2013 20:21:17
Hi Ann163,
here there is whatever is recoverable.
I wish you an happy new year,
Davide
Słupy.sm (2,61 МиБ) скачан 22 раз(а).
#15 Опубликовано: 28.12.2013 06:26:14
Ann163
Ann163
Hi w3b5urf3r,
thank you very much for fixing it
I also wish you a Happy New Year!
Ann
