Deleting picture in smath file not possible
Deleting picture in smath file not possible - Сообщения
#1 Опубликовано: 02.09.2021 05:52:10
Stefan Müller
Stefan Müller
0 сообщений из 45 понравились пользователям.
Hey,
while working i considere a problem with a jpg picture.
I can put it in the smath file but i am not able to re delete the picture.
Deleting Picture not possible.sm (544,4 КиБ) скачан 1252 раз(а).
Is there somehow a way to delete the picture. The icon is grey so i cannot click it
Best regards Stefan
#2 Опубликовано: 02.09.2021 07:18:06
You have to select the region then you can delete it (left-click on a point outside the region, hold down the mouse button and move over the region; it will become blue-colored).
This is a general rule. Any region when focused (left click on the region) it is supposed on interaction within the content and therefore you cannot delete the container (also depending on the region you might have different options in the context menu when it is focused or selected).
Stefan Müller 07.09.2021 07:21:00
#3 Опубликовано: 02.09.2021 08:39:23
Stefan Müller
Stefan Müller
ok thank you i got it :-)
#4 Опубликовано: 02.09.2021 11:21:47
Stefan,
1. Capture/select your image [Paint, WinGrab ...]
2. Paste in IrfanView ... check if you can reduced colors
3. In IrfanView, you can sharpen from poor web image.
4. ... as well resample/resize
At this point, copy/paste in your Smath work sheet.
Click on the image, press Delete from the keyboard.
