Problem with arithmetic ans symbols
Problem with arithmetic ans symbols - Сообщения
#1 Опубликовано: 22.08.2014 13:19:16
juan.veraz
juan.veraz
Hello, I'm from Chile and I'm using Smath since few days. I've this problem, when I put the symbol with the keyboard for exponential or any symbol, the program closes. I don't know why . If someone know how can I fix this problem, please say me.
Thanks
PD: Sorry if my English is not very good. I hope that it's close enough to understanding.
#2 Опубликовано: 22.08.2014 19:46:05
1 440 сообщений из 2 928 понравились пользователям.
Hello juan.veraz
What version of SMath are you using? What is your operating system?
You might try to test if you have the same issues using this portable distribution
Another test that you can do is to use the on-screen keyboard, with your keyboard layout and with the english layout and looking if you notice the same problems
#3 Опубликовано: 22.08.2014 21:03:32
juan.veraz
juan.veraz
I using this version:
Versión Smath
My OS is Ubuntu 13.10.
I also will try the other alternatives that you recommended. I hope you answer.
Thanks.
#4 Опубликовано: 24.08.2014 07:34:45
Because you work on an unix system, probably there are issues between the mono libraries (at least the version that you are using - what is? is the last version?) and the new way to handle the keyboard inputs introduced by Andrey recently; would be useful to know if some other unix user has your same issues
#5 Опубликовано: 28.08.2014 00:30:11
juan.veraz
juan.veraz
I don't know what version of mono I have (how can I know?). A guy sent me a email and he said that the Smath works fine in his Ubuntu, but with the version 14 of Ubuntu. I hope if someone use the Ubuntu 13.10 and happens the same, leave a message here.
